Old 04-24-2025, 08:29 AM   #11
Liked 10,595 Times in 2,190 Posts
Default Re: Help with class, Stock eliminator mopar
It will be good to see another kool car at the track. Good luck.
Old 04-24-2025, 01:54 PM   #12
GTS340
Liked 1,295 Times in 392 Posts
Tom Auger runs a 63 Dodge 330 two door with a 383 4bbl. His runs H/SA
https://garagehotrods.com/2019/04/26...-63-dodge-330/
Paul H
Old 04-27-2025, 05:58 AM   #13
Cglrcng
Cglrcng's Avatar
Liked 306 Times in 174 Posts
Mark, has that one got the horizontal pushbutton shifter on the left? If so you will love those buttons. Fingers curled under the buttons shift with the thumb push down lightly and squeeze the trigger that last 1/8th inch. Just remember though if you go with a reverse manual valve body 2nd gear freewheels...get good brakes on the car!
Do not be a victim of the death spiral of a transmission you cannot use to actually downshift in a car that is also very heavy and has inertia. And get a double master cylinder in it no matter what. Cool car though...you'll love it!
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is online now   Reply With Quote
Old 04-27-2025, 09:34 AM   #14
Paul Precht
Paul Precht's Avatar
Liked 306 Times in 115 Posts
It's first gear that freewheels unless you use a valve body that holds the low/reverse band in first.
