Old 08-27-2009, 03:14 AM   #1
CJohnson
CJohnson's Avatar
Default Bog off the line ?
Hey guys.
I am having troubles with a bog / stutter off the line. I have gotten used to launching the car like this but I would like to know what the cause of the bog is
its a mild 355
Flat top pistons
Hydraulic roller cam .510/.520 lift (not sure on the duration)
Edelbrock performer RPM heads
It has a 750 holley (vaccume secondarys) on it right now currently jetted at 68 - 73's it used to have 70 - 75's but the change did not seem to make to big of a difference
I do have access to a 750 holley mechanical secondaries would this be significantly better ? i've heard the vaccume secondaries are more for street use and bog off instant WOT ?
Like i said it just kind of stutters and then takes off.
any help is appreciated, Thanks.
Craig
C693
CJohnson is offline   Reply With Quote
Old 08-27-2009, 09:08 AM   #2
kennyd
Default Re: Bog off the line ?
go up 1 size on squirter, and pos .5 to 1.0 higher # power valve if vaccum will allow, what kind of vac nos does it pull idling in gear
kennyd is offline   Reply With Quote
Old 08-27-2009, 09:34 AM   #3
Chris1529
Liked 70 Times in 29 Posts
I agree that you need a different squirter. I would take a bigger swing at it than one size though.
what size is in it now? probably a low thirties. I'd go up into t he low to mid 40's on squirter size.
you have a momentary lean condition which is causing this problem.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 08-27-2009, 09:39 AM   #4
Hans Olsson
Hans Olsson's Avatar
Craig,
what are your 60ft time?
Hans Olsson is offline   Reply With Quote
Old 08-27-2009, 11:20 AM   #5
BlueOval Ralph
Banned
1. Make sure you have full travel on acc pump arm with.015 clearance at full stroke
2. Use red pump cam as i remember it is a #330 in the full postion.
3. If you get into a .040 range squrt. You need the hollow pump screw. Don't over tighten it.
4. It would also help to open the Idle Feed restriction in metering body about .003 (usally .033 or.035.
BlueOval Ralph is offline   Reply With Quote
Old 08-27-2009, 12:20 PM   #6
CJohnson
CJohnson's Avatar
Hey, guys thanks for all your help. Here are the specs on my carb
holley 750 4150
PRI Shooter - 25
PRI Pump Cam - 330 #1
Power Valve - 6.5
Second Spring - Purple
The car runs mid - low 13's and ive cut a best of a 1.880 but this is with my 12 bolt in my cutlass with stock upper and lower control arms, my pinion angle was off by a mile. Now it's set up right with adjustable 12 bolt uppers no hop bars drag shocks ect.
I'm racing this weekend and i'm going to try some changes to the carb on the friday test and tune.
Old 08-27-2009, 02:56 PM   #7
CJohnson
CJohnson's Avatar
Thanks, I went to mopac today and picked up some bigger squirters 37's were the biggest they had should be a big difference from the 25's i had in there ? and I also picked up a 7.5 power valve 1 size up from the 6.5 i had. I will try it at the track tomorrow.
Old 08-27-2009, 03:16 PM   #8
blasttime
blasttime's Avatar
Smile Re: Bog off the line ?
Take your squirter and calipers to a hobby shop and buy a pin vice and drill bits its cheaper than buying squirters. There very easy to drill out. Have a great day
blasttime is offline   Reply With Quote
Old 08-27-2009, 03:19 PM   #9
CJohnson
CJohnson's Avatar
Thanks, good idea but i have already bought the squirters
Old 08-27-2009, 08:30 PM   #10
Jody Lang
Liked 92 Times in 29 Posts
I think your sec. spring is too light for your combination. Start your weekend out with the plain (stock) spring and be prepared to try a heavier one.
The heads might be a little big for your combination and might also need a bigger squirter to make up for lack of velocity.
Is this a #3310?
My bracket car has a 3310 on it. It runs mid 11s. Plain spring, 72 76 jets with a 028 squirter.
Good luck.
Jody Lang is offline   Reply With Quote
