Liked 166 Times in 71 Posts
1969 Chevelle
F/SA 396/325HP (NHRA factored 316) Car was originally 307/Glide, came from US. Car is good and solid but paint and body is showing it’s age. Other than small patches in 1/4’s and SS hood it’s original sheet metal. Have the flat hood to go with. -Chassis- -8 point mild steel roll bar tied into frame and lower control arm mounts -Kirkey Seats -Urethane body bushings -Global West front control arm bushings -Santhuff front springs, QA1 Stocker star front shocks -Tubular rear control arms -Tubular rear upper crossmember braces -Rear Upper Arm relocaters on housing -Strange Double adjustable rear shocks -Wilwood super lite brakes all four corners -12 bolt with Strange 33 spline spool and axles, Richmond 4.33 Pro gears, 1350 yoke -1350 driveshaft -Engine- -Currently running as 396/325/316hp fits F/G/H -Sleeved and grouted 454 4 bolt block -GM Steel Crank -Manley H-Beam rods -JE Pistons with Total Seal thin stock legal ring pack -290 casting heads by Armstrong. Manley severe duty valves, PAC conical springs and retainers, Comp 1/2” Stud rocker setup -Bullet 54mm Steel Core cam -Trend tool steel DLC coated lifters -Trend Pushrods -Deano Q-Jet -MSD pro billet distributor, 7AL2, pro power coil, two step -ATI Damper and flexplate. -Approx 20 1/8 mile runs since last checkover, and 325hp cam installed. Under 100 runs total. -Trans- -Metric 200 3 speed with 2.75 low, JPT reverse pattern valve body, Alto clutches, Ultra bell (2 years old) -ATI Treemaster Converter, 5300 flash stall -Turbo Action Cheetah shifter -TWRP Sheild (2 years old) Car has recently been .70 under 1/8 mile index for F/SA as 396/325 combo, with more left. Should equate to approx .90/.95 under in 1/4 mile. This was with heavy oil and about 2000ft DA. Last season went .79 under F/SA 1/4 mile with 396/350/335 combo. Comes with that camshaft as well. Fits E/F/G with this combo -Spare Parts- Comes with the following -Bullet 54mm Steel core 396/350 cam (Factored 335hp) -Pair of 063 Heads previously ran -2 extra intakes (1969 Only- scarce) -Flat hood -Any other random associated stuff I find. Car will need slicks and belts for next season- Other wise ready to go and should be a -1.00 under car in good weather or with some more tweaking. Asking price $26000 USD or $35000 CAD May be Interested in partial trades. Contact Chris at 902-956-1962 or chippersperformance@gmail.com
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
