Old 04-02-2008, 02:15 PM   #1
Hnasko Racing
Question Questions w/ running Alcohol?
Of course we know im the noob im the board. I'll also be opening another post for advice.
But Dragsters/cars running on Alcohol, what is the going rate per gallon in the Southern States (FL,etc)
Also do most tracks sell Alcohol at the pumps? If not where do you get it from?
Hnasko Racing is offline   Reply With Quote
Old 04-02-2008, 03:58 PM   #2
Hnasko Racing
Unhappy Re: Questions w/ running Alcohol?
Noone knows average Alcohol prices? *cries*
Old 04-02-2008, 05:10 PM   #3
Charlie Yannetti
Liked 192 Times in 83 Posts
Default Re: Questions w/ running Alcohol?
Call VP Fuels......... they'll tell you exactly how much it costs.......... I'd tell you but I don't run Alcohol........
Charlie Yannetti is offline   Reply With Quote
Old 04-02-2008, 06:04 PM   #4
Hnasko Racing
What type of alcohol is normally run in super comp style dragsters w/ Rons Flying Toilet?
METHANOL ? M 1 ? M 3 ? etc?
Old 04-02-2008, 11:04 PM   #5
Hnasko Racing
Question Re: Questions w/ running Alcohol?
Shesh, I know their are a lot guys out their running alcohol noone wants to educate the newbie?
I need to learn because a lot of the dragsters im seeing for sale are runnin on alkly!
Old 04-02-2008, 11:27 PM   #6
Greencar
Ask your questions here you will get a lot of info and there is a discussion on methanol price going on today. http://drr.infopop.cc/eve/forums/a/cfrm/f/4976075 - or go to www.dragraceresults.com, then click "bracket talk" on the left column.
Greencar is offline   Reply With Quote
Old 04-03-2008, 02:28 AM   #7
Robbie Draughon
Liked 29 Times in 5 Posts
My fuel guy sells Hank Thomas alcohol for $200 a drum with top lube.
SS/AM 2917
Robbie Draughon is offline   Reply With Quote
Old 04-03-2008, 08:47 AM   #8
Hnasko Racing
Is the only way to get Alky is by the drum?
Old 04-03-2008, 10:03 AM   #9
Steve OB
Steve OB's Avatar
Send a message via Yahoo to Steve OB
By the drum is the best way & the way most people deal with it. You go through so much volume you need a lot in hand. Some tracks do sell it by the gallon & most don't include lube & usually more per gallon.
The price is up. More down south than up here in Ohio. It is like $160 a drum up here & $200+ down there. I run with a Rons set up & it will run on any kind of methanol. Use top lube if your not going to drain the system weekly.
I hope this helps!
Steve OB is offline   Reply With Quote
Old 04-03-2008, 10:37 AM   #10
Hnasko Racing
Thanks Steve for some input.
What is top lube? Is that in the fuel mix? Or something you have to add?
Is it cheaper to run a dragster on alky or race fuel?
Also on most dragsters in 8 second range on alky how much fuel could they burn in one pass?
How long do you think a drum would last pass wise?
How often do you have to change the oil when running alky? or plugs?
It would prob be a 460 bbc.
