Old 01-15-2009, 07:04 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default TH350 Blowing Fluid
Towards the end of the 2008 season I went to a deeper gear spinning the engine/trans a little higher. Now I have a problem of transmission fluid blowing out of the plastic vent in the case. I see that TCI offers a reservoir for this problem on a TH400 or Glide but not for the TH350. Also, I remember seeing a super comp rail that had the vent line plumbed into the pan with AN line (aftermarket case).
I would like to just run a line from the vent to the pan, but I am not sure if this will fix the problem since any transmission case pressure will then have no way (that I know of) to release.
I am open to any ideas to keep my under carriage and garage floor clean.
Thanks,
Chad
Chad E532 is offline   Reply With Quote
Old 01-15-2009, 08:25 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: TH350 Blowing Fluid
Two things to look at. Make sure the oil level is correctly set. Too high of an oil level might cause the oil to come out the breather. Make sure you have the correct dipstick and tube for the type of pan you have. Factory Deep pans are to lower the oil level, not increase the amount of oil. Deep pan transmissions from the factory get different dipsticks, and tubes that lower the hot full mark on the stick, compared to the pan flange. Also another typical source of oil out the breather comes from cross leaks across the pump halves. Those surfaces are bolted together, and need to be flat, so they seal on each other. If the breather passage in the pump gets flooded with line pressure oil, or converter feed oil, it can over load the circuit, and the extra will blow out the breather. You could also put a small line on the breather fitting, and run it into a vented plastic bottle tie wrapped to the transmission crossmember, that will help keep the overflow off the track or garage floor.
Old 01-15-2009, 09:40 PM   #3
Chad E532
Chad E532's Avatar
Thanks SS3011,
I am running a TCI deep cast pan but with a stock dip stick. I typically run the fluid at the "add a pint" mark but maybe that is too high.
I am going to have to pull it out and replace the front pump gasket and seal just to be sure and then I can run a tap into the vent hole to add some plumbing.
Old 01-15-2009, 10:29 PM   #4
T200's are just as bad or worse.
The catch cans are ok until you forget to empty it .
I just braze a short nipple, made out of a piece of brake tubing, up near the top of the filler tube, and run a small hose from the vent, up to it.
Old 01-16-2009, 11:47 PM   #5
Joe Toller
Liked 9 Times in 9 Posts
I actually do that on my demo derby car trannies, works great.
Old 01-18-2009, 08:22 PM   #6
SSGN
SSGN's Avatar
Liked 203 Times in 52 Posts
Question Re: TH350 Blowing Fluid
That is a great idea,but how does the trani vent to atmoshere when useing a locking dipstick.I am thinking you would build pressure in the trans.
Old 01-18-2009, 09:02 PM   #7
The old non-locking dipsticks I use don't seal very well!
