Old 01-24-2009, 07:25 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default Roll Bar Rear Bar Question
I am in the middle of installation of a S&W roll bar kit in my 77 Camaro. I want to keep the back seat so I ordered up the extra long bars that run though the package tray instead of the rear seat. They are long enough to run all the way back to the taillight panel.
My question is should I run the bars all the way back to the rear of the trunk which will tie the bars into the rear leaf spring perches, or would it be best to have another bend put in the tubes to drop them closer to the shock mounts?
Thanks
Chad
Chad E532 is online now   Reply With Quote
Old 01-24-2009, 07:32 PM   #2
Liked 1,875 Times in 422 Posts
Default Re: Roll Bar Rear Bar Question
I'd run them all the way to the back, and if you want to add a little stiffness, drop a kicker off of that bar on each side to about where the shock mounts are. There's probably about a 3-4 pound weight gain there, but on a stock floor pan car, the added stiffness is worth it.
Old 01-24-2009, 09:18 PM   #3
Philip Saran
Liked 14 Times in 11 Posts
Chad,
I am having the S&W roll bar kit installed in my 1974 Duster right now,
no rear seat, but my two rear bars tie into the top of where the rear part
of my frame connectors are welded which is a few inch's ahead of the
front of my spring mounts.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 01-25-2009, 12:46 AM   #4
Run to Rund
Liked 54 Times in 27 Posts
By the time you weld in the required crossbar, the rear seat will be virtually inaccessible. Might as well save the weight, remove it and make up some "upholstery" and a piece of carpet.
Old 01-25-2009, 02:15 AM   #5
Todd Bailey
Liked 33 Times in 17 Posts
Chad,
You have a PM.
Todd Bailey is offline   Reply With Quote
