hey guys I need help it blowes the tires off i take timing out to get the car to hook its a dog thinking i,m killing the motor to compinsate for a sup. thats not working its a factory type sup. rear sup. is Wolfe racecraft, all adj. double antiroll bar, strange double adj. shock, factory springs all in factory mounting points 68 chevelle 3550 with driver, ub machine front control arms, strange single front shock, moroso trick spring, car 48. percent to the rear,slicks m/h 26x8.5 any HELP.....thanks.
That's a lot of trick parts with some dainty little slicks...
Jeff Lee 7494 D/S '70 AMX |
15 by 10 / 5.5 backspace 28/10.5 MT. There is a difference
#4 | |
got the car to hook on hoosier,s best time 5.70 with some testing looking to go in the high 50,s
Liked 1,443 Times in 302 Posts
I was think the same thing, all good until the tires. If you got it work ever, you were doing pretty good. The tuning window must be pretty small.
James Schaechter 3163 STK |
Liked 5 Times in 3 Posts
I take it your running the 8.5 wide class? If so you running it on just the motor? Are you using a trans brake? If the answer is yes to these don't spary it till it get atleast 60' out & try a lower starting line RPM
You can do all you want to the back end, but if the front dont work, you wont hook. My pic is on 30x9x15 slicks. You need some good springs and shocks up front. www.santhuffshocks.com and KONI street adjustables will get er done.....for a while
*** 72 Malibu *** 1.329-3.99-6.28@106.71-9.98@131 best 60ft to date-1.2997 |
