Old 07-12-2010, 07:31 PM   #1
Coach
Coach's Avatar
Liked 2 Times in 2 Posts
Default Turbo 350 overflow canister
Need a little help on finding a turbo 350 overflow canister.
I am tired of always cleaning the buttom of my race car after every race!
Coach
Coach is offline   Reply With Quote
Old 07-12-2010, 07:57 PM   #2
Jim Cimarolli
Liked 166 Times in 46 Posts
Default Re: Turbo 350 overflow canister
You have a PM.
Jim Cimarolli is offline   Reply With Quote
Old 07-12-2010, 08:16 PM   #3
Ed Wright
Ed Wright's Avatar
I just tig welded an aluminum -6 male fitting to the Moroso vacuum pump catch can I have my valve cover hooked to for a crank case breather. Used a -6 pushlock hose end and clear tubing from Ace Hardware clamped to the plastic vent with the cap removed. Strange you are getting a mess. My clear hose hardly ever has anything in it.
My trans brake does leak, however. :-(
Ed Wright 4156 SS/JA
Old 07-12-2010, 09:33 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
JAZ jr dragster 1 pint breather tanks work nicely for this. ....Tom
Old 07-13-2010, 02:24 PM   #5
Jim Kaekel
Liked 536 Times in 110 Posts
x2 on the one pint JAZ canisters. Just run a hose from the vent tube to the overflow, which can be mounted to the firewall.
Jim Kaekel 3836 STK
Old 07-13-2010, 02:41 PM   #6
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi Guys,
I just did a TH-350 for a friends GT car and installed a catch can that was made by DEWZEN and it was a very nice piece and I would recommend that you take a look at their catch cans. They also make catch cans for other applications.
www.dewzen.com
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 07-17-2010, 09:02 AM   #7
Hugh Meeks
Stinnett makes a nice one as well. It has a bracket that allows to bolt the can to the tailhousing. Out of the way but easy to reach to drain.
Hugh
Hugh Meeks is offline   Reply With Quote
