Old 01-17-2011, 05:29 PM   #1
shockme668
shockme668's Avatar
Default MSD ignition no spark question
I have a MSD 6AL with a blaster ss coil and have a spark from the coil, but not at the plug.. I remove the wire from the cap and put it near ground and cranked the motor and there is a spark from the coil. I put the wire back on the cap and remove the wire at the plugs put near ground crank the motor, no spark at the plug. The cap and rotor are new. I am stumped where to go next...Any assistance would be appreciated...Thanks
shockme668 is offline   Reply With Quote
Old 01-17-2011, 06:07 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: MSD ignition no spark question
follow this procedure...
http://www.msdignition.com/page.aspx?id=3206
Old 01-17-2011, 08:15 PM   #3
shockme668
shockme668's Avatar
I tried the link you sent me...I was getting a spark from the Blaster ss coil but it was weak and needed to be about 1/8 inch to ground not the recommended 1/2 inch...I just got back from the auto part store with a new coil and it started...Thanks for the help......
