Old 03-20-2011, 09:27 PM   #1
THE LEGEND
Default t-stop?
My Biondo Stop has the blades slotted.
My dedenbear does not.
Do I need to slot the blades in the dedenbear ????
Chip
THE LEGEND is offline   Reply With Quote
Old 03-21-2011, 03:29 PM   #2
wayne sipos
wayne sipos's Avatar
Default Re: t-stop?
if you are going to run methanol you should ............ it stops fuel puddling....simple to do ....grind the swedged screws before you try to remove the throttle blades....bolt them together then use a bandsaw to cut the slots.....loctite the screws back in shafts or use button head allen screws.............did that to my dedenbear stop
Wayne Sipos HR 3959
wayne sipos is offline   Reply With Quote
