Old 05-22-2011, 08:27 PM   #1
Pistol Pete
Pistol Pete's Avatar
Liked 816 Times in 215 Posts
Default Generators
What is a nice "quite" generator for say under $500.
I know Honda's are good but tooo much $$$$$.
I have a noisy Coleman, but it came with the trailer so i've been using it.
Thx for the advice.
Pistol Pete
Old 05-22-2011, 10:59 PM   #2
Eric Kitzan
Eric Kitzan's Avatar
Default Re: Generators
If you are looking for something small to run a battery charger and other small things a 1000 watt honda I think is around 1000.00 bucks. I had a 3000 watt that I paid around 2000.00 for it, very good generator. I know you want to spend under 500.00 but I don't think you will find a QUIET one for that price.
Eric Kitzan
66 Chevelle Malibu Wagon
Stocker
Eric Kitzan is offline   Reply With Quote
Old 05-22-2011, 11:55 PM   #3
Philip Saran
Liked 14 Times in 11 Posts
A Honda 2000i will run you about $900 or so nowdays.
If you need something bigger than that your options are
two Honda 2000i with a connector to give you 4000 watts
or a Honda 3000 for around $1800.
Depends on your needs. A Honda 2000i weights about
35 lbs and a Honda 3000 about 135 lbs but comes with
wheels.
Yamaha also makes similar units in size and price that
are quiet.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 05-23-2011, 09:20 AM   #4
Mile High
Quiet generators generally aren't inexpensive. Bought my 3200 Subaru from a place in Illinois on Ebay 6 or 7 years ago. I've only had to change oil and has 1400 hours. I like the hour meter. Another choice and it's quiet.
http://www.continentalgenerators.com...generator.html
Jeff
Street legal 64 Falcon Sprint with 410W living in Texas.
Stock - Super Stock fan
Mile High is offline   Reply With Quote
Old 05-23-2011, 09:34 AM   #5
jmcarter
jmcarter's Avatar
Liked 3,252 Times in 989 Posts
The quiet Yamaha is the best in my experience. I can run my 3000 all night to run heaters, refrig, etc and neighbors don't even know it's running. The 1000's aren't that much cheaper than a 2000, which only weighs 44lbs. You get what you pay for and your neighbors at the track will appreciate it too!
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-23-2011, 10:49 AM   #6
FED 387
Liked 336 Times in 183 Posts
look around you usually can find a good used Onan or other RV gen for that price
