Old 08-14-2011, 09:36 PM   #1
Rick Shirey
Default roadster wheelbase
I am looking at a Spitzer roadster with the present owner telling me it has a wheelbase of 107". What do you feel are the et and mph limits on a car with this wheelbase? I am trying to get in a car that is fairly versatile, one that I could race in the footbrake,electronics and S/G classes. As far as chassis certification it is IHRA certified for 7.50 and slower, would I be correct in assuming that it would pass NHRA certification to the same ET?
Rick Shirey is offline   Reply With Quote
Old 08-15-2011, 12:54 AM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Default Re: roadster wheelbase
Have the car checked for NHRA certification as a condition of purchace.
If its an older IHRA cert.[or NHRA for that matter]. it may not have all the necessary tubes in the proper places.
107" WB will let get you down most tracks with a bunch of horsepower,provided the chassis is set up properly.
My Vette is 108" and I rarely have any troubles at 163-65 mph unless the track is a complete piece of junk,and then nobodys going to make it down it anyway!
Old 08-15-2011, 09:55 AM   #3
63corvette
Liked 359 Times in 103 Posts
Just a guess but on my last re-certification I was told to keep the 7.50 I would need to add a tube in the Trans area. It did certify for 8.50 and slower which is plenty quick for a 105" roadster which mine is. It goes 9.90 at 160 to 169 depending on how good the air is.
I agree with Tom, make it a condition of the purchase if you want the 7.50 certification and if it does not you should be able to buy it for less.
Good Luck
Rick Cates
63corvette is offline   Reply With Quote
Old 08-15-2011, 10:34 AM   #4
Rick Shirey
Tom and Rick, thanks for your replies. I have contacted Spitzer and they have reinforced the information you supplied. He did say their present cars are built at a 125" WB, but he saw no reason why this car would not work in S/G at the speeds you both mentioned.
Old 08-15-2011, 11:45 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
Rick,
If wheelbase was the problem then a lot of the Gen 3 Camaro's would be in trouble with their 101" wheeldase. Vinney's Comp roadster I had made quite a few passes @ 145. I think the type rear tire made more difference in it's handling than anything. Those hi-growth thin sidewall tires are a handfull after the finishline. They had to come down and settle a little before using the brakes and chute. With the type tire used in S/G racing I see no problems.
Adger Smith (Former SS)
Old 08-15-2011, 02:56 PM   #6
Tom Goldman
You're right about the tires ,Adger.
I tried a set of soft sidewall tires when I first built my roadster to try and get some more MPH, and you could not drive the finishline with those tires!
I used to go 165 in my Willys when I cut it loose ,on a 100" wheelbase.
You knew you where going fast then!!
