Old 12-20-2011, 11:49 AM   #1
HR 9505
Default Setting Throttle stop RPM?
How is the best way to set throttle stop rpm? Do you just simply activate the TS and open the throttle wide open with it in park and set it like that or does it have to be under a load?
HR 9505 is offline   Reply With Quote
Old 12-20-2011, 12:12 PM   #2
Bob Verwold
Bob Verwold's Avatar
Default Re: Setting Throttle stop RPM?
Biondo Racing has all the info you'll need to set the stop...
I'd do the link thing but don't know how ....But it's at the top of the page.
Bob Verwold is offline   Reply With Quote
Old 12-20-2011, 12:21 PM   #3
Chris Williams
Chris Williams's Avatar
I needs to be under load. Two ways to do it: try it on the track, check your log/recording tach, and adjust from there is the most accurate.
Or the other way. Up on stands, switch your box from linkage/undercarb to the opposite setting, press the TB button and nail it. That will put you on the stop and on the TB, check it, adjust, repeat. Just don't forget to set your box back to the correct setting, or you run will be a disaster...
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 12-20-2011, 12:49 PM   #4
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
Or the other way. Up on stands, switch your box from linkage/undercarb to the opposite setting, press the TB button and nail it. That will put you on the stop and on the TB, check it, adjust, repeat. Just don't forget to set your box back to the correct setting, or you run will be a disaster...[/QUOTE]
You forgot to tell him to have it in low gear when he presses the trans brake button
Chuck
C and W Racing is offline   Reply With Quote
Old 12-20-2011, 01:28 PM   #5
HR 9505
Thanks guys......i figured it had to be under load but wanted to make sure.
Old 12-20-2011, 02:31 PM   #6
Chris Williams
Chuck
Oops! I do it enough that I forgot that step. Thanks!
Of course he'd just be spinning in reverse
