Couldn't get into factored HP for 1969 ZL1 on NHRA website. Anybody know what it is? It's a stick car. Also, when I was looking at the specs for this engine the other day, it said outer spring with damper. It used to say outer and inner spring with damper. I know the factory used inner/outer with a damper back in 1969.
Liked 800 Times in 237 Posts
445 for Stock, 476 for Super Stock. Stick and auto. are the same h.p.
"That'll never work....." |
Liked 1,924 Times in 432 Posts
The configuration of the stock spring no longer matters.
It's a tough and expensive combination.
Alan Roehrich 212A G/S |
#4 | |
Yes, it is definitely tough and expensive but I got it done. Didn't you run a 427 (ZL1 combo?) at one time? |
Al, what Alan is saying is that NHRA has changed the rules on stocker valve springs. You no longer have to comply with the specs. listed in the NHRA Blueprint Specs. (pressure, spring style, etc.). You also don't need to run stock style rockers (roller rocker arms permitted). From the current NHRA rule book:
"Any valve spring permitted, provided no modification to head is performed. Steel valve-spring retainers mandatory. Spring cups permitted ONLY if no modification to head is required." If you got your parts before these rule changes, make darn sure you talk with Comp. Cams to make sure your springs are up to the task. Keeping the lifter in contact with the lobe is critical with these motors. -Al
#6 | |
I'm saying the NHRA no longer cares if your spring configuration matches OE spec or the guide. Chris or Tim may have a better spring for you. Kevin Cradduck and I have the parts for a ZL-1, we set it aside when the new cars entered the picture. We will get it out of mothballs and finish it now. Jimmy Bridges gets after me on a weekly basis telling me it is what should be in Kevin's car. We will start this season (a late start) with a fresh aluminum head 396/375 in both cars. We previously ran the 427/425 in the orange stocker, with the aluminum heads, at 435HP.
I appreciate both of you helping me with my questions. I did upgraded to roller rockers a couple of years ago. So I could run a beehive spring as long as I run a steel retainer? It would be nice to run a smaller and lighter steel retainer on the nose for some more ponies!
Jimmy told me years ago about angle milling the 401 head to get it down to closed chamber CCs. .125 off the bottom at 0 on top, redrilling head bolt holes, etc... |
