Old 03-27-2016, 09:42 PM   #1
wood338P
wood338P's Avatar
Default stock gm computer cars
what is the trick to making these modern 1998-2001 f bodies (more) consistent. I have a 01 v6 car that I use to travel out of state to bracket race and 7 out of 10 passes it is predictable ( .03/.04), but then it will slow a tenth or a tenth and a half two passes in a row and then jump back the other direction and run the quickest of the day. I'm not familiar with the preparing these computer cars. I try to keep the car at normal operating temperature and traction isn't a problem. I would just like to be able to keep it in the ballpark so I can give myself a shot each time down the track.
Adam Woodmancy 338P
wood338P is offline   Reply With Quote
Old 03-29-2016, 05:15 AM   #2
GTX JOHN
Liked 2,484 Times in 697 Posts
Default Re: stock gm computer cars
My son runs a cooler stat/ Programmer to start fans earlier and lean
out fuel mixture / Ices throttle body. He has won several track championship with it. He also uses drag radials.
John Irving
741 Stock
741 Super Stock
Old 03-29-2016, 07:42 PM   #3
nj02z
OLSD. Open loop speed density tune.
nj02z is offline   Reply With Quote
Old 03-31-2016, 12:15 AM   #4
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
This might be the anti-knock sensor, which will retard the timing as the engine gets hot, then returns to normal after a cool down. If you don't want to spend $ on a programmer or aftermarket ECM, you might get away with simply running higher octane fuel.
Maybe add a switch that lets you run the electric fan at will, especially when the engine is off.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 03-31-2016, 01:45 PM   #5
Jeff Stout
Liked 704 Times in 281 Posts
On my 06 Magnum I was keeping track of intake heat (harbor freight heat gun) and ET. After awhile a pattern was showing. It did help a lot dialing later in rounds. Not perfect but helpful.
Old 04-01-2016, 12:14 PM   #6
Adam Woodmancy
Adam Woodmancy's Avatar
thank you guys for the replies.
1972 LeMans NMCA O/C
Adam Woodmancy is offline   Reply With Quote
