Old 05-03-2016, 11:37 AM   #1
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Default Project " Preparation H "...preparing a 2005 Mustang GT
I love the looks of the 2008-2014 Cobra Jets but there was no way I could afford one.
This is as close as I will get, so here goes the story of the build of my S197 Mustang 3 Valve GT up to the point that I took it to the Div. 3 race at Indy in late April.
I wanted to build it for H/SA and see what the car would run with the required Stock Eliminator mods done to the car.
Link to that day @ Indy:
http://classracer.com/classforum/showthread.php?t=62048
After thinking about building one of these cars and searching all the ads on the internet for over a year, I finally got my big break in late Feb. of this year.
A friend sent me a screenshot of a rebuilt 2005 Mustang GT and I found the CL ad.
Up to this point it was the cheapest 3 valve GT I could find. I contacted the owner and locked in a deal where I would be the first person to look at the car.
After looking at it and driving it for 5 minutes, I threw the seller an offer and we exchanged cash for the title.
The car had been hit front and rear and was rebuilt with a clean KY rebuilt title. I had my car, but now I had to work fast to get it ready for Indy.
The car mechanically checked out good. It had fantastic anti-lock brakes, strong engine and the trans felt fine. This was the very first 3 valve Mustang GT I had ever driven. Up to that point I had been used to my 95 Mustang GTs.
The A/C and power steering felt great. Too bad because both would soon be taken off.
It had the wrong headlights, turn signal markers, and was missing the lower grille and left rear side marker. I managed to get a set of headlights locally for 40 bucks.
The other items I had to get on ebay because the local salvage yard here did not have any 2005 and newer Mustangs.
So I paid about $ 140 for all the correct lights, markers and grill, so now the body of the car was legal.
The first mod would be to allow my skinny drag wheels to work. These cars have huge (and heavy) front brakes but require a special part number ARP studs.
Thanks to the S197 forums, I armed myself with enough info to order the correct 3 inch wheel studs and a stud installer. All 10 studs were $ 123.00 delivered. Not cheap, but they are the only ones I could find.
I also purchased a stud installer for 23 bucks. That is one great tool. I would screw a lug nut on the old stud, lightly tap on the stud while applying pulling pressure on the backside of the hub with a crowbar to try and absorb some of the impact of the hammer. Those hubs are sealed and non serviceable, so I did not want to damage the bearings any more than possible.
( I put a lug nut on the old stud while hammering it out to prevent it from hitting the ABS tone ring )
All 5 studs were installed in less than 20 minutes and the wheel fit perfect.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 05-03-2016, 11:56 AM   #2
ALMACK
ALMACK's Avatar
Default Re: Project " Preparation H "...preparing a 2005 Mustang GT
Next up for ol' Prep H was the driveshaft loop : $ 20.00 swap meet special with grade 5 bolts. 1/4 " x 2.0 as per spec.
After that came the removal of the power steering pump and A/C compressor. I re-arranged the front pulleys and took the grooved one on the driver's side and put it onto the passenger side. Then I found a 49.5 inch belt in my stash of parts and tried it. Dead on perfect ! What luck.
Now I had my short belt.
Now I had my alt. and water pump as the only items drawing from the engine.
Eventually I want to put an electric water pump on the car and relocate the alternator down low on the pass. side, but those pumps are over 400 bucks new. Maybe later.
I/PS '95 Mustang GT
Old 05-03-2016, 12:10 PM   #3
ALMACK
ALMACK's Avatar
This is the first fitting of the wheels and tires that I "borrowed" from my Bronco II drag truck.
The front 26 inch tires did not look good with the Mustang's wheel opening.
So I used some Hoosier 28 inch tall front drag tires that I had bought from a friend for 100 bucks. With mounting and balancing I had $130.00 into my skinnies now.
That 4wd look in the rear would be fixed later...
I/PS '95 Mustang GT
Old 05-03-2016, 12:22 PM   #4
ALMACK
ALMACK's Avatar
Now the fun begins...this was where I started to get nervous. I did not know how the interior panels were held into place and I did not have a service manual showing an exploded view of the panel layout.
So, I just slowly pulled on a panel until it popped.
I gotta say, that sound still makes me quezzy, but luckily after the whole interior was taken out, I had only broke one tab, and that was because I took the trim out over the passenger door out of sequence.
Notice how the door panel leather trim is sagging down...a common problem on these cars. Some time with 3M headliner adhesive and thoroughly cleaning off the old gray foam from the panels fixed that.
Now that I know the sequence of removal and replacement, it would easier if the need arises.
Not shown is the huge Shaker system speaker and amp box that was located on the pass. side in the trunk. It weighed exatly 60 lbs by itself !
I/PS '95 Mustang GT
Old 05-03-2016, 12:48 PM   #5
ALMACK
ALMACK's Avatar
After searching the net for a roll bar kit, I felt the 8 point S&W Race Parts kit was best suited for how I wanted the bar fit the car.
My primary goal was to retain the factory seats and not have to cut the door arm rests for the side bars.
Mission accomplished on both.
Dealing with S&W was a great experience. Very professional and knowledgeable.
I was concerned how I was going to be able to lower the main hoop down to weld the rear bars to the top of the hoop, but luckily Ford already provided me with the answer.
These plugs pop out and with a slight stretch of the feet of the main hoop, they fit thru the holes.
I/PS '95 Mustang GT
Old 05-03-2016, 01:26 PM   #6
ALMACK
ALMACK's Avatar
This was my very first time installing a roll bar, and I have to admit it was very intimidating to me at first until I tackled the job.
It gets tedious. Lots of fitting, remove, grind, re-fit, grind some more....and so on, and so on.
Now I know why chassis and fab shops charge what they do for a roll bar installation. A lot of time is involved to get it to fit within the tight confines of these late model cars.
I could have just hacked up the back seat and drove the rear bar thru the cushion, or replace that lightweight seat with carpeting, but I love the look of the car's factory interior. Besides, the rear seats all combined can't be more than 20 lbs.
What I liked about the S&W kit was how the rear bars worked in the car...thru the package tray.
As a racer that works by myself quite a bit, I have to get inventive on how to hold items without a second set of hands.
I fabbed up 2 brackets that bolted to the factory seat belt anchors and was fully adjustable.
I could now move the main hoop forward or backwards or left to right to obtain a perfect and consistent position:
Now I had the ability to hold the hoop in the same position all the time. I had to revise it a couple of times, but this would turn out to be one of the best tools I built for this build.
I/PS '95 Mustang GT
