Running super street. Will I gain any mph going from a 4.86 rear gear to 4.30? 950 hp car trapping about 140-142ish
Liked 431 Times in 224 Posts
Difficult to say. I would doubt it, as the car will have a more difficult time getting up to speed when it comes off the stop.
S/ST 51 S/C 53 |
Liked 100 Times in 51 Posts
I agree with Lenny5160. Converter lockup will change dramatically, It will slip more. Maybe try the 4.56 gear.
Dan
Dan Foley SC 4698 |
My thoughts too. Was getting suggestions from others that I would pick up alot but I'm not sold on it
Liked 1,887 Times in 579 Posts
Rpm=mph
That’s the short version
KEITH MAYERS 2-1/2 X somebody Still many X nobody Last edited by Keith 944; 02-20-2018 at 02:17 PM. |
Liked 3,249 Times in 988 Posts
Hear lots of good things about the APD Max Speed....seems like better way to go if you don't mind changing to a different setup. There's another thread on throttle stops which got me doing some research.
I'm a little confused here. What does your car weigh? 950 HP and only 142 mph? Something doesn't calculate. I had a Super Street car that went 148-150 with 875 HP.
Car weighed 3000 lbs. (67 Cuda). I used 4.56 gears and hit the finish at about 7600 rpm. Engine made peak power at 7300. |
Liked 4 Times in 3 Posts
I have a 505 bbc in a 70 chevelle that made 860 on stinnets dyno a few tears ago and it only runs 137,139 best. 4.88 gear 14.5 32 tires. 3150 with me
