Old 05-22-2018, 12:33 PM   #1
j gardiner
Liked 55 Times in 29 Posts
Default Mechanical stops
Do you guys have any input on mechanical throttle stops. Do they work well? Who makes a good one etc.? Thanks.
j gardiner is offline   Reply With Quote
Old 05-22-2018, 08:22 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Default Re: Mechanical stops
Are you referring to a fixed restrictor plate type stop or a timed under carb stop ?
Old 05-22-2018, 09:22 PM   #3
j gardiner
I am talking about a fixed linkage type, possibly under carb type, I just don't have a lot of hood clearance. I just need to slow up around .2 to .3
Old 05-23-2018, 07:41 PM   #4
rob7181
Jeff,
I use the 4500 style ET genie, before that I made a stop out of an aluminum spacer. I may still have a 4150 style stop that I use to use on smaller motors.
Rob
rob7181 is offline   Reply With Quote
Old 05-23-2018, 08:07 PM   #5
Hacksaw
Liked 314 Times in 177 Posts
If it were me, I would just make the carb adjustable on the secondaries or a positive stop under the pedal. For .2 secs on your et slip you may need that in the summer heat. Save your money.
Old 06-04-2018, 09:47 AM   #6
Tom Goldman
Hacksaw's right for that little amount I'd dead bolt under the pedal or linkage ,or use weight .
Way back when I ran Super Street , I dead stopped for the main amount and adjusted up or down for the last .10th or so with weight ,
