Liked 799 Times in 236 Posts
In general, what's the guideline for finished journal sizes on a .013 stroked stocker crank?
Can one that's .010 and not stroked finish at .020? Thanks! -Al
"That'll never work....." |
Liked 10,850 Times in 2,254 Posts
It all depends on a few things. Is the stroke on long side or short side of spec. How close is the index, 90*, 90*, 90*, 90*. The size of crankpin. We have made a +.013 crank and it be 10/10.
Liked 348 Times in 152 Posts
No, one that's already .010 would finish at .030. You can't take .013 off one side of the throw when there's only .010 to offset grind with.
Phil Molski PMR Performance S/C 1623 |
Liked 312 Times in 175 Posts
#5 | |
If you take .010 off ONE side, you've moved the centerline .005, increasing the stroke by .010.
If you grind .0065 off one side, where do you remove the remaining .0035? bearings usually come in undersizes of .010, with plus or minus .001 You need to move the centerline .0065 to achieve .013 offset
Phil Molski PMR Performance S/C 1623 Last edited by pmrphil; 06-20-2019 at 08:21 PM. |
The center-line of the crank pin is moved .0065 away from center-line of mains. If stroke on stock crank is 3.483'' instead 3.480'' and the pin is on the high side of tolerance it will make a stroke of 3.493'' grinding it .010'' under to the low side. But usually it takes a .030'' under on the rods to get .013'' stroke. If the index is good why not make it .014'' long?
Liked 804 Times in 168 Posts
Larry has it correct , it is a math exercise. The one thing that you also must realize is that indexing can not be fixed much by grinding. As an example, a 3" stroke crank would take a move of .026 for each degree it is off. to move it that much, it would need to be ground a minimum of .052 under.
Dave Casey 1330 STK |
