Liked 5 Times in 4 Posts
Did a little bit of searching on here but couldn't quite find the right answer. Any bracket racers running the Mickey Thompson or Hoosier radials? I have an S10 I was trying to fill up the fender wells with a 14-in slick but the Hoosier tires I bought with the wheels have a 2-in bulge. I know the radials have a lot less bulge, but I haven't talked to too many people who have tried them successfully.
#2 | |
Liked 312 Times in 175 Posts
I'm going to do some more measuring but that was the tire I was looking at.
Liked 1,954 Times in 590 Posts
This is the tire I run on my super stock car. Good tire. Hooks good. good life. I would give them a try.
Mike Pearson 2485 SS |
I would but I have the wrong backspace. I bought some MT 10.5x33x15Ws,they fit exactly flush to outside fender.I needed 5 1/2 B's and screwed up somehow 🤔
Liked 6 Times in 3 Posts
I’ve had stellar results with MT’s PBR. I’ve been running the 28x9 for a few years. Now in the midst of some work to make room for more tire, and will be running the PBR in a 29.5 x 10.5 moving forward. I also have a number of buddies that love the nPBR; one of them recently tried a Hoosier radial, and says he lost half a tenth somehow (???), but is seeing similar consistency.
Liked 232 Times in 69 Posts
I have been running the Mickey Thompson Pro Bracket Radial 29.5x10.5 for 3 years. I got over 180 runs on the first set. When I brought them over to the Mickey Thompson trailer, they asked why I wanted new ones. I said I had almost 150 runs on them, they asked if they were still hooking ok, I said yes, they said, "Run them till the cords show, or you start seeing your 60 foot change." I ran them for another month, then bought a new set just because they had over 180 runs on them. BEST hooking tire I have ever used. Soon as I installed them, 60 foot went from 1.46-1.50 down to 1.37-1.40. Car used to roll over the tire and porpoise 2-3 times before hooking. Now its doing 2-3 foot wheel stands! This is the ONLY tire I will use on my combination. It is a stiff side wall tire. I do not use tubes, and they are not screwed to the tire. Also, I've only had to add air to them a couple of times throughout the season, they do not move as far as pressure goes. Mickey Thompson said they know cars that have over 250 runs on these tires.
Liked 52 Times in 32 Posts
I have a set of American Racing Trak Stars, Dbl Beadlocks , 15x12's, with 5.5 back space, 4.5 bolt. Section width = 16.250" with Hoosier 31.5" 13.5" 15" Radials.
SC 707Y |
with a 12" rim, section measures 16.250, same tire.
SC 707Y |
