Old 06-06-2021, 08:59 PM   #1
EVIL CLOWN
Default Throttle stop carb adjustment
Just looking for some advice running a 540 on a number 1 stop carb is set up for power been banging bearings due to destination I don’t have 02 or egt’s just wondering if anyone has advice on tuning it for stop was told that when you put a stop under it gets very lean it’s a 1250 carb I know everyone tells me it’s to big not the best combo any help will be appreciated thanks
EVIL CLOWN is offline   Reply With Quote
Old 06-06-2021, 11:41 PM   #2
Jeff Stout
Liked 708 Times in 285 Posts
Default Re: Throttle stop carb adjustment
Lack of proper quality fuel can promote hammering bearings to death.
Old 06-07-2021, 12:55 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Fuel and timing would be the first place to look . especially if you use a grid and pull timing out on the stop . cylinder pressure skyrockets up and can kill bearings [and cranks]. and yes that knowledge is from personal experience.
That said , the carb is way too big for a 540. again ,I speak from experience .
I've had 1050's 1150's 1250's on 1000hp 565's and found the 1050 to be the best all around for the Stinnett under carb stop I run.
All of the above carbs were from name shops and all ran lean when on the stop.
I recently put on a 1050 carb from ATM Innovations . It is the first carb to not go dead lean on the stop, pulls great off the stop with no lag in rpm gain and has a great fuel curve for the entire run. and I lost no MPH over the 1150.
Plus they were great people to deal with .
Old 06-07-2021, 09:44 PM   #4
EVIL CLOWN
The carbs that I run are done by CFm and book very good carbs to big for stop racing irk very well off stop I know these guys don’t do stop carbs just looking to adjust what I have I run vp c 14 fuel trying to see if anyone knows when they go lean on the stop is what I’m thinking but what do I know need to put a 1050 on it in the future timing is 37 degrees and we don’t pull any timing out on the run motor runs 8.40s in 3080 lb car makes 1004 on dyno
Old 06-08-2021, 10:40 AM   #5
Tom Goldman
Without fuel data ,it's difficult to focus the cause ,or the time of detonation, If that is what is causing the bearing issue.
Are the spark plugs also showing signs of detonation? they should if the detonation is bad enough to cause bearing damage.
several carbs I've run have gone as lean as 15.3 AFR while on the stop ,running the same timing and fuel with 16 to 1 compression and conventional heads , not that any two engines want the same timing ,especially with your car weighing 700#'s more than mine.
Old 06-08-2021, 08:30 PM   #6
EVIL CLOWN
The plugs are showing signs thanks fo your help probably going to run no stop until I get some o2 s going to call some carb guys this week that do carbs for stop racing don’t know if I will get anywhere then send me your carb or I can sell you one I’d like to put a stunner 1050 on it but not buying one now
