Liked 187 Times in 58 Posts
Need help with the deck height , NHRA list a 302 at .047 Gasket ,and the deck height at .0005 is this correct
John Ancona 717 STK / SS |
Liked 783 Times in 195 Posts
Yes.
Thank You for the help
so the piston is five tenths above the deck
John Ancona 717 STK / SS Last edited by john ancona; 03-31-2025 at 07:47 PM. |
Liked 705 Times in 204 Posts
Negative vs. Positive Clearance:
Negative clearance means the piston protrudes slightly from the deck surface, while positive clearance means the piston sits a bit inside the cylinder bore. The .0005 on the chart appears to be a positive number so the piston should be below the deck. I assume if it’s assembled .0005 above a .048 gasket gets you back to correct deck clearance.
Mike 7570 A/SA Last edited by Mike Gray; 03-31-2025 at 11:29 PM. |
Yes.
Liked 2,493 Times in 700 Posts
Basically, a Zero Deck Piston for all practical purposes.
