Liked 61 Times in 22 Posts
2007 EASTEXAS CHEVY COBALT Comp/SS
*Pro stock 4 link & anti roll *TBM brakes all around *Strange struts with fast shock valving *40 spline m/w axles *M/W center/Lamb support Indy gear set up *Penske rear shock air operated *Milodon fuel pump with new fuel lines *Racepak smart wire system *Racepak all 8 oz?s & every sensor you can get from wheelie bars to temperature *MSD grid *Precision shifter (forward pattern) *Car comes with pro jacks & pump *Racing radios & charger come with car *Spare drive shaft, springs, lifters, wheels and tires. Also wing to put in SS. To many parts to list. *Push bar also comes with car for your golf cart *Third pedal in car if needed MOTORS *E/SMA or HA/A classes 1 motor 322 splayed valve built by (RCE) motor will be fresh with 0 runs. Motor has 2 carb or 1 carb set up. Whatever class you run. Motor has the best of the Best parts. Jim from (RCE) will confirm. 1 motor 322 SB2 built new 1.5 yrs ago by (RCE). Everything but block is brand new. CFE heads & intake. Motor has 2 carb or 1 carb set up also. Best money can buy!! TRANSMISSION Pro Trans with adaptor 254/154 ratio with 4 passes currently/ freshen up from Larry Allen. Has all the good clutches. Pro trans with adaptor 247/151 ratio that is fresh from Larry Allen. Coan bolt together converter with multiple stators. This car has the best parts money can buy. Has won multiple Division/National events. Will sell the car with one motor or both. Not selling Rolling! One of the nicest Cobalts out there. (NO TRADES) Everything goes $180,000 1 Motor & Trans(either motor) $150,000 Contact: Matt Alvey 502-790-4429, matthew.alvey@trane.com |
