Not sure if it has been mentioned on here before but it seems in most cases the diaper will touch a header tube on plenty of applications. Are these diapers burn proof?
www.EngineHones.com |
If you call dre he will install a heat shield on his diaper. It worked for me !
Liked 21 Times in 6 Posts
DRE is the only sporsman diaper that has heat cloth available for header clearance,also motor mounts cut out.We have these in stock call with any questions 217-454-5289
I have one of these with the heat shield. It pretty much touches a couple of the primary tubes...with no problems ...
Ted
Ted Barnes 1511 HR |
