Old 02-19-2012, 06:02 PM   #1
FrankM
FrankM's Avatar
Liked 3 Times in 2 Posts
Default 3rd gen camaro throttle linkage?
I am setting my camaro to run sst & hr. I am running a throttle stop on the carb and want to convert the cable. Can you guys give me recommendations, solid rod or morse cable? Can you post or send pics?
Thanks,
Frank
FrankM is offline   Reply With Quote
Old 02-28-2012, 08:38 AM   #2
FrankM
FrankM's Avatar
Default Re: 3rd gen camaro throttle linkage?
I may not have worded the question properly. I am installing a throttle stop (Biondo PCTS-SH) and the factory cable I believe is not a good choice due to too much stretch for consistency. Do you guys have recommendations, solid linkage or morse? I will only be cutting .3 to .5 ET. If you have done this can you send pics.
Thanks,
Frank
Old 02-28-2012, 12:35 PM   #3
Ken MacNicol
Ken MacNicol's Avatar
Liked 26 Times in 12 Posts
I use a inline with a factory cable and CSR bracket with no problems.
Ken MacNicol is offline   Reply With Quote
Old 02-28-2012, 01:38 PM   #4
FrankM
FrankM's Avatar
Ken, are you running a dominator or a 4150? Which CSR bracket do you have? I'm running a 4150 and have a CSR bracket for the snap in cable that I've been using without the t-stop but didn't think that will work. Thanks for the help, need all I can get.
Old 02-28-2012, 04:15 PM   #5
Keith 944
Keith 944's Avatar
frank, if you are that close to the index, i would just add weight. this can be VERY consistant. and could save you a lot of time and $.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 02-28-2012, 05:31 PM   #6
Ken MacNicol
I ran a 4150 until last year, but now have a 4500. They do not have a extended bracket for a snap in cable, so I modified mine a little. I still have it if you are interested.
