05-17-2012, 10:46 AM | #1 |
bowtie heads?
i was all sold on the phase 3 --0034 heads for modified that the iron heads are required, but i see some other numbers that look good for a hi-winding 302. i need your input and suggestions----thanks
05-17-2012, 09:30 PM | #2 | |
Re: bowtie heads?
Check your PM. |
05-21-2012, 10:44 AM | #3 |
Re: bowtie heads?
I know that the Comp Cams RHS 14 degree is legal for SS/CS
05-21-2012, 03:36 PM | #4 |
Re: bowtie heads?
05-22-2012, 07:46 AM | #5 |
Re: bowtie heads?
Comp got the okay last winter, I'm not sure why it's not in the guide, but I know SS/CS guys have bought some, and may be running them. I sure did'nt want them approved because I was in the middle of building a iron headed LS1.
05-22-2012, 02:20 PM | #6 |
Liked 1,093 Times in 286 Posts
Re: bowtie heads?
I'd want to see written approval from Glendora before I tried to build and run a 14 degree aftermarket head engine in SS/CS. I have not even seen a written revision of the rule which states "OEM casting,,,,,,, with OEM number cast into head".
Alan Roehrich 212A G/S |
05-22-2012, 03:26 PM | #7 | |
Re: bowtie heads?
The cylinder head, P/N 12561873, was only used for two years on GM trucks with the LR4 and LQ4 engines The LS1 cast iron cylinder head is a truck engine cylinder head. Super Stock stock rules say truck engines are prohibited. I am with Alan here, where is the written proof from NHRA? |
