Old 07-22-2013, 10:41 PM   #1
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Question rear gear ratio
Hey guys i need i little help with gear selection for running superstreet,i have a 5.67 gear in my car now and the engine revs up to 8100 rpm in the 1/4 and my speed is about 129, but my engine peaked hp is at 7600 to 7700 rpm on the dyno should i go with a 5.43 to lower the rpm and increase the mph or leave it as is to run superstreet.
astikhossw is offline   Reply With Quote
Old 07-23-2013, 08:02 AM   #2
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
Default Re: rear gear ratio
If it was my car, I would change the gear. I'm assuming you are running a small block with that much gear. In my super gas car, I run a 4.10 and have been thinking of trying a 3.89
Chuck
C and W Racing is offline   Reply With Quote
Old 07-23-2013, 11:11 AM   #3
astikhossw
astikhossw's Avatar
It is a ford v-6 that i have been running in superstreet a little at 2450 lbs.,but i have been running the 5.67 gear and was just wondering if the trend is to get the mph up as much as possible and still keep the engine in are above peak hp.Thanks
Old 07-24-2013, 07:53 AM   #4
cdh124
Send a message via AIM to cdh124
Chuck
Chuck,
What size tire are you running?
Doug Humes
cdh124 is offline   Reply With Quote
Old 07-24-2013, 08:04 AM   #5
C and W Racing
I run a Hoosier 33.5/17-16 co7 compound
Chuck
Old 08-07-2013, 01:29 PM   #6
supergas4
Liked 6 Times in 5 Posts
a 6cyl.runs 10.90 at s/st weight ?
supergas4 is offline   Reply With Quote
Old 08-07-2013, 10:43 PM   #7
astikhossw
astikhossw's Avatar
yep as low as 2000 lbs and it can run 10.08 130 mph wide open.
