Old 01-15-2009, 12:23 AM   #21
SGSST109E
Liked 126 Times in 61 Posts
Default Re: Radial Wabble Problem
I had MT 14/32's on 14" rims on a SG 68 camaro with ladder bars and single adjustable shocks front and rear. I ran 12.5 psi. Never had the wabble effect just found out how quickly the tire wear away. You can use radials succesfully in a car with a clutchless trans.
SGSST109E is offline   Reply With Quote
Old 01-15-2009, 11:45 AM   #22
Roger K Fain
In your description of the problem you left out many of the possible contributing factors. What is happening to the vehicle is the suspension is unloading upon deceleration and finding weak points in the structure or geometry. The radials are a major contributor to the reaction of the suspension, but not the initiater. If you have a four-link suspension, you may have a problem with your wishbone flexing, bending, or just loose in the mounting.Check to ensure that all connecting points of bars are sufficiently secured and not allowed to "wobble", thus keeping the car in a straight line until the suspension collects itself.
Additionally, make sure the front suspension reacts equally in separation and compression and is totally fluid in movement.
Roger K Fain is offline   Reply With Quote
