#11 |
The motor oil is now named Amsoil Signature Series 0W30. The also have a 0W20.
#12 |
Liked 484 Times in 160 Posts
Castrol also frowns on using any additives with their oil. As the rep stated " why undo something that our chemists have engineered into our oil ?"
#13 | |
Liked 138 Times in 51 Posts
Those are not the same oils. The Dominator Series is new as of last year and are fortiufied more for the racing environment. The Signature Series 0W-30 may have gotten reformulated a year or two ago. I'm only speculating, but it may have to do with newer model emission regulations and compatibility, similar to a new diesel formulation for 2007 & newer diesel trucks. I believe the zinc content has something to do with it. The race oils, older diesel, including the HDD 5w-30, and some of the others, still have a large amount of zinc and similar additives. It's all good stuff nonetheless.
LOCOMOTION Racing Last edited by Myron Piatek; 01-21-2009 at 10:39 PM. |
#14 |
I would have to agree with Alan on the head gaskets. I have used Cometics on our 283 and 327s and reuse them 3 times, then I take them off and save them. I probably could use them again. They get pretty reasonable when you get to use them more than once. You tell them the bore size and thickness and they take care of it.
James Schaechter 3163 STK |
#15 | |
#16 | |
#17 |
I appreciate it, but once I found out that the 7733SH1 was the replacement...I got it and I believe it is what I will use at this point. I am hoping to have her running in about a week...so as my normal price and time estimates go it will probably be about 2 weeks and twice the costs that I had orignially planned for.
Tim Wilson HR/SST 4301 |
#18 | |
7733SH1 aprox .015, with your .002 makes .017...gonna hit. let me know what you see when it comes appart...
Bub Whitaker Last edited by Bub Whitaker; 01-23-2009 at 10:07 AM. |
#19 |
Well, I have been scared away from making the clearance that tight...I just am trying to get as much out of everything as possible and taking thousandths away from the piston to head clearance will definitely increase compression which is definitely a gain of some sort. I decided to go with a .028 thick gasket which will yield about .030 clearance.
#20 |
Liked 20 Times in 15 Posts
Mobil/ Mobil 1 makes the base oils for all synthetic oils. I used to sell race oils. When you read the specs for synthetic motor oil and compare them all, this is what you will find: everyone has a hard one for additives that makes their oil different. When you look very close, many are only slightly different competitors to Mobil 1. They really only offer slight advantages. Most are only noticeable in lab reports. SAVE YOUR MONEY. Brad penn 0-30,10-30 semi synthetic and Valvolone VR1 are the best for the $ spent. Amsoil does offer a oil analisys that will answer any questions about the oil you are using. They contract with a private company. You can deal with this company direct. OH BY THE WAY, ask 50 racers about oil and you'll get 53 answers.
