Old 01-13-2009, 12:38 PM   #21
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
Default Re: Vacumm Pump
Star makes a very nice piece. I have used Aerospace as well and my only complaint with them is they are not hard anodized on the inside and do wear a bit with use. I am currently using a Moroso enhanced 4 vane on my 1050hp 520" B1.
As for a picture here is mine. It is a bit hard to see but it is there under/next to the filter.
sst7250 is offline   Reply With Quote
Old 01-22-2009, 10:34 AM   #22
Anthony Barrett
Cool Re: Vacumm Pump
Thank you all for your advice. I wound up buying a kit from Reher Morrison with a 3 vane Moroso pump and the adjustable regulator that goes right on the pump. I am hoping you all can help me with one more question. What is the best way to adjust the regulator?
Anthony Barrett is offline   Reply With Quote
Old 01-22-2009, 06:36 PM   #23
Bryan Gillespie
Banned
Your going to need a gauge
Try about 10 lbs to start, I'v heard to much will suck your gaskets in.
Bryan Gillespie is offline   Reply With Quote
