Old 01-29-2009, 05:26 PM   #1
JCChildress
JCChildress's Avatar
Liked 13 Times in 6 Posts
Default Best builder of Carter Thermoquads ?
Who is the best builder for a Super Stock Thermoquad ? Will it make any difference having a -8AN line going into as opposed to a -6AN line ?
Thanks
JCChildress is offline   Reply With Quote
Old 01-29-2009, 07:23 PM   #2
Bub Whitaker
Default Re: Best builder of Carter Thermoquads ?
I'm curious also... they are by far the most tempermental things I have ever seen!!!
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 01-29-2009, 08:51 PM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Best builder of Carter Thermoquads ?
I haven't dome any business with him, but he is well known on the moparts.com web site:
http://www.thermoquads.com/
LOCOMOTION Racing
Old 01-29-2009, 09:06 PM   #4
Bub Whitaker
Thanks Myron, but I need Racer testimonal as to who they used and I think JC is lookin for this info also. I've done 3 in house, one for shop test on customers engines and two for engines wev'e sent out the door for customers. All of them have been a challenge, hours to do, findin parts and then multiple pulls on the dyno to set air fuel, butterfly angles, air door shape and setting. All the ones my customers have come up with we need to fix... Someone out there must know...
Bub Whitaker
Old 01-29-2009, 09:12 PM   #5
Jim Storms
Liked 4 Times in 2 Posts
I have #8 on my superstocker and #6 on my stocker, really don't see any difference either way...steve wann has had Brad Vanlant do a couple carbs, says he is pretty good with them.
Jim Storms is offline   Reply With Quote
Old 01-29-2009, 09:16 PM   #6
Bub Whitaker
So is Brad Vanlant an individual who does this for a livin or a side line and how do we get in touch with him?
Bub Whitaker
Old 01-29-2009, 09:22 PM   #7
Jim Storms
I dont' think he does them for a living! he races stock elim.. ill see Steve Wann in a couple days on my way to Pamona, i will check with him.. I believe Brad lives in the Midwest..
Old 01-29-2009, 09:28 PM   #8
aspen7709
Steve Wann is good with TQ's. Angelo Phillips and I have been doing our own based on Steves original blueprint and have had good success.Jack Foshee is also really good with them also.we do away with the metering rod setup and run holley jets and a few other tricks.Right now we are testing to see wether the side inlet or the bottom inlet is better for fuel feed. and we have been using -6 line with a bypass system.Also use a good air cleaner.my company sells a single 4 copy of the fresh air style unit the works killer.
aspen7709 is offline   Reply With Quote
Old 01-29-2009, 09:58 PM   #9
Bub Whitaker
now were talkin.. sounds like most u guys are doin your own and it sounds like your getting a handle on it. JC need to get with you guys and do his own also... Jim Storms, do you do your own? since you have Stock and Superstock using Thermoquad?
Bub Whitaker
Old 01-29-2009, 10:12 PM   #10
Jim Storms
I don't want to say ive Mastard them, but ive done a pretty good job,, learning from Steve Wann, Bill Bushmaker, and a few other's... i guess ill know in about 7 days when i make a pass @ Pamona.... i just built a new one for my stocker.. I have a good back up that Marlin Bogner had done for my superstocker. so i guess if the new don't work it's back to plan B
