Liked 165 Times in 59 Posts
any one out there using a accusump?,where are you guys locating the tank ,i have mine in the engine compartment looking to move it,,,,,,,, gmonde
I mounted mine in the trunk...ran a high pressure hydraulic line along the framerail then connected to the electric solenoid .....works great and also has extra capacity,,,,Wayne
Wayne Sipos HR 3959 |
#3 | |
Liked 100 Times in 45 Posts
Ed F.
Former NHRA #1945 Former IHRA #1945 T/SA |
Liked 8 Times in 7 Posts
It's legal.
look in the oil pump section "accumulator permitted" it looks like thats where its going ,i moved it to the right rear down bar behind the passengers seat,but read in the rule book cannot be located in drivers compartment,but is that considered drivers compartment ?????? gmonde
Passenger compartment is from firewall to rear bulkhead, door to door and roof to floor. Even if it were legal in the passenger compartment, if I were a tech and saw that "hidden" behind anything I would be doing some investigating!
Personally I would want the lines as short as possible so on your AMC it would be passenger side inner front fender or firewall. If you can mount it vertical you might consider it on the passenger side radiator support. It's about time NHRA allowed these in Stock!
Jeff Lee 7494 D/S '70 AMX |
jeff thats where i had it but had to put the battery back in that location,the problem is this thing is not the smallest unit to find a good mounting place,mite be looking at the trunk area gmonde
Liked 883 Times in 237 Posts
Just put it in front of the radiator on the radiator crossmember. ...I've put them there for years with no problems ,Aris also has his in that location on the SS/C car. ...If you set the pressure balance correctly you can put it just about anywhere,as they say ,it aint rocket science.....Tom
Liked 320 Times in 102 Posts
Just a heads up,
As per the NHRA rule book of 2009 it states in General Regulations Section 4:2 That "Any liquid other than engine fuel being used, located behind the front firewall (on a front-engine car), is considered ballast and is prohibited, except for intercooler tanks that contain water and/or ice only." I took a look at some of the old rulebooks that I had around and found one that went back to 1996 and the rule was in 4:2 and the wording was the same with the exception of the intercooler tanks. Looks like putting the accumulator to the rear of the firewall is a good way to get bounced from tech. Bob
