Liked 3 Times in 2 Posts
I have a chance to pick up a 1996 Camaro for my son, the car is in real nice condition, and is real affordable. The guy just put a new engine and trans in it, car already has headers, and flowmasters, and a 3.5 gear in it.
how much work is it to make oneof these a decent running Stocker? I have been playing with Mustangs for the past 15 years, and planned on putting him in a Mustang, but this deal is almost too good to pass up. I know I will need to put a roll bar in it, and change the wheels and tires, and most likely the gear as well. What else do you guys do to them? and what class do they run? If I looked at it right looks like it falls into D or E/SA, is that right??
NHRA: Comp 2200 - S/C 2201 NMRA 2012 Outlaw 10.5 #10 |
Liked 228 Times in 70 Posts
A '96 Camaro would be a natural D car it can also run C and E. C = 3235 lb. D = 3410 E = 3580. I would estimate 20-25 thousand to have a competitive LT-1 car. If you find some second hand stuff (EFI system, wheels and tires, tranny and convertor), it should help costs because just those can easily be around $8,000 together new. Also, you need to change out the 10 bolt rearend for a 12 bolt with either 4.88 or 5.14 gears.
Liked 19 Times in 7 Posts
The 2 most expensive and important things about those cars is the computer stuff and the rear end. Why GM put such a wimpy rear in those cars is a question I would like to ask. 7.5 rears break with a street tire on them. They should have had an 8.5 10 bolt at least. Smith Performance Specialties can sell you everything you need to make these cars work and live under drag strip abuse. Most of the 96 and up Camaro stockers are his cars. Check out his website.
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
Thanks guys, i am not looking to make this a top qualifying car by any means, I am simply looking to be able to at least hit the index and maybe go .1-.3 under. He will just be racing at Divisional races anyway for at least a year or two.
I'm not sure where the LT1 stockers are shifted, but if below 7000 RPM the factory PCM (computer) can be used just fine. Software and an interface cable for tuning one would be a lot cheaper than an aftermarket ECU and harness.
Ed Wright 4156 SS/JA |
