Old 02-21-2009, 12:19 PM   #1
luckydog
luckydog's Avatar
Default 421/434 RPM Range
What kind of RPM to you bigger small block guys run?
Damien Hazelton
Lucky Dog Racing
luckydog is offline   Reply With Quote
Old 02-21-2009, 01:11 PM   #2
Bob Verwold
Bob Verwold's Avatar
Default Re: 421/434 RPM Range
Not enough...hahaha
you have email
Bob Verwold is offline   Reply With Quote
Old 02-21-2009, 02:39 PM   #3
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: 421/434 RPM Range
Aw,,Bob,,,,, I was hoping you'd answer him on this. I've been kicking around the idea of doing one of these engines for a while, but am hesitant because I have 4:88s (Dana 60) and a 29 1/2 tall tire and worry that I would spin it too tight on the top end. Just curious I guess,, oh well, thanks anyway.
Danny Durham
Old 02-21-2009, 09:50 PM   #4
Lynnmsp
I run a 434 and shift at 6800 and go thru at 7000 to 7100.
Lynnmsp is offline   Reply With Quote
Old 02-22-2009, 12:41 AM   #5
SUPER STREET ROB
I Run a 434 in a 3000# car with a 350 turbo trans and a 430 rear gear and I shift at 6800 and go threw at 6800
SUPER STREET ROB is offline   Reply With Quote
Old 02-22-2009, 08:51 AM   #6
Bob Verwold
I'm guessing your running a glide, what rear gear ,how tall of a tire and your MPH. I'm wondering if my converter is going south...............
Old 02-22-2009, 10:26 AM   #7
Lynnmsp
Bob,I run a glide with a 4.71 gear 14-32 tire.On the stop 134-135MPH.I only made one run off the stop and it went 140MPH.
Old 02-23-2009, 11:09 AM   #8
Eddie Arnold Jr.
Not counting last year ,,,,, I've ran a small block for Quite a while .
I ran 5.00 gears , 1.92 1st gear in the trans , left on the converter every pass @ 5800 RPM and went through
at 7600/7700 ,,,, in super gas Trim the car weighed 2240 and would run 9.900 @ 148/151 depending on air .
It was a 421 with Dart 23 degree heads .
I ran good parts rebuilt engine ( rings, bearings , head gaskets etc... ) every 200 runs !
Colorful racer # 37
Eddie Arnold Jr. 3934 SC, SG
Eddie Arnold Jr. is offline   Reply With Quote
Old 02-23-2009, 02:02 PM   #9
rod butcher
Liked 132 Times in 27 Posts
My 434 in S/St trim 2830 lbs runs 10.90@149-151 depending on the air. Motor turns 7600 with 14.5x 32 and 4.57 gear. Motor makes 830@7400 w/ 676 ft/lbs torque @ 5800. When I first built this motor I ran 4.86 gear and 8" convertor in S/G trim (2600lbs) and went thru @ 8000. I now use 9" conv with the 4.57 gear.
rod butcher is offline   Reply With Quote
