Old 06-10-2009, 08:28 AM   #1
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
Unhappy transbrake question
I know this has been beat to death but mine is a little different. I have a 4000 lb pickup with a 540 and a t400 with ATI brake and valve body and their button. Is it the trans brake that's slow or is it me? I cannot hit a .400 tree at all.
Floyd Staggs 787 SST
Old 06-10-2009, 11:57 AM   #2
63corvette
Liked 362 Times in 105 Posts
Default Re: transbrake question
The turbo 400 is just a little slow on a .4 tree to begin with.
The 4000 lb weight is also an issue.
Do you know what gear ratio gear set you have?
There are several ratio's for the 400 and that can make a difference for the .4 tree.
It is just hard to make a 4000 lb vehicle move quickly out of the lights on a .4 tree.
Good Luck with your issue and it probably is not you being slow.
Rick
63corvette is offline   Reply With Quote
Old 06-10-2009, 12:38 PM   #3
Floyd Staggs
Rick
I don't know what gearset I have. I would have to ask Leo over at Remac. He built it.
Yeah, I figured the weight was somewhat of an issue but it 60's 1.41-2 so it gets moving pretty quick.
Maybe I just better stick to the Sst .500 light and forget about the nostalgia gas classes.
Thank you for your answers. I appreciate it.
Old 06-10-2009, 03:25 PM   #4
S/G 386N
S/G 386N's Avatar
Send a message via AIM to S/G 386N
ATI's are just that slow. Had the same problem in my car. Switched it out to a Coan transbrake and picked up about .030-.040.
JJ Nance
'06 Don Davis C5 Corvette
S/G 386N is offline   Reply With Quote
Old 06-10-2009, 04:40 PM   #5
Floyd Staggs
Did you change the whole valve body or just the selenoid?
Old 06-10-2009, 06:12 PM   #6
63corvette
If JJ was talking about a PG vs Turbo 400 they are totally different animals.
JJ has a Davis car which will only weigh about 2200 or 2300 lbs with him in it vs your 4000 lbs.
Rick
Old 06-10-2009, 08:41 PM   #7
S/G 386N
S/G 386N's Avatar
whole valve body. At least on the PG, the ati brake is a spring, while the coan is hydraulic.
JJ Nance
Old 06-10-2009, 10:57 PM   #8
Caperat
Talking Re: transbrake question
You are way too heavy for a trans brake. TOOOOO hard on the crank and driveline parts. Footbrake launch and take the side stepping the clutch like shock out of the expensive to replace parts.
Caperat is offline   Reply With Quote
Old 06-11-2009, 08:01 AM   #9
Floyd Staggs
Now you tell me! I should have asked the question before I did it, huh.
Maybe I should put a glide in it.
Old 06-11-2009, 08:34 AM   #10
Bill Baer
Exclamation Re: transbrake question
At 4000# If you put a glide in it, you had better buy the best parts/planetary that you can get. I suspect that a vehicle that heavy would destroy the GM stuff very quckly.
I would think you would be better off buying fiberglass and lexan to lighten that beast up. You will not only get better vehicle reaction times but you will break less stuff.
