Old 07-28-2009, 09:10 PM   #1
CJohnson
CJohnson's Avatar
Default "G" Body suspention tips ?
Hey there, I have a 1984 cutlass that I am slowly turning into a stock eliminator but right now its just a 13 second bracket car with a 355.
I just recently swapped out my 7.5" ten bolt 3.73 posi, for a 12 bolt 4.88 posi and i am running 30x9 goodyear radials with the steeper gear. to make these tires fit I had to run cargo coils in the rear does anyone know if these work well for weight transfer in these cars ?
I'm also using the stock upper control arms (The pinion angle is way off and i am getting major shutter off the starting line)
I ran my car at the National open last weekend for the first time with the 12 bolt and like i said i was getting big time shutter off the launch, and also my 60's were all over the place from a 1.956 to a 1.880 and it felt like it was hooking up every pass
Will a set of adjustable upper control arms fix the in consistancy off the line ? and is there any other tips to get "G" bodies leaving the starting line better ?
Thanks,
Craig - C693
CJohnson is offline   Reply With Quote
Old 07-28-2009, 09:45 PM   #2
skooter
Default Re: "G" Body suspention tips ?
Maliburacing.com
skooter is offline   Reply With Quote
Old 07-28-2009, 11:58 PM   #3
CJohnson
CJohnson's Avatar
Thanks "skooter" .. alot of interesting info on the forums.
Old 07-29-2009, 04:52 AM   #4
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
realoldspower.com
Old 07-29-2009, 08:17 AM   #5
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
http://www.hrpartsandstuff.com/
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 07-29-2009, 08:21 AM   #6
Brian Fink
Liked 28 Times in 9 Posts
You need to start fresh with coil springs both front and rear ( Moroso will work ). Shocks need to be race specific and in this case a call to Calvert should give you what you need . Any of the major control arm companies will also get you in the ballpark along with a one degree pinion angle ( to start ). Also, as Alf Wiebe will tell you , use a rear sway bar !
Brian Fink is offline   Reply With Quote
Old 07-29-2009, 08:31 AM   #7
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
sounds like binding of upper control arms. stock uppers and old 12 bolts cause binding due to angularity differences. need the uppers changed to rid yourself of this problem to start.
chris ok is offline   Reply With Quote
Old 07-29-2009, 08:43 AM   #8
Bob Gullett
I guess the question is, is the 12 bolt modified to fit the G-body? Are the upper ears located in the proper angle to the upper control arms? If it was an "A" body 12 bolt, the upper control arm attachments are not in the proper location. You probably can force the control arms to fit but it will seriously bind. Post a little more info on the 12 bolt install.
68 Chevy11 327 F/S
Old 07-29-2009, 11:01 AM   #9
skooter
They make the control arms to put the "A" body rear in the "G" body, with the correct angles.
Can't remember who, maybe the "Iceman", I think there's a product line under that name, think he even sold/sells on Ebay.
Old 07-29-2009, 11:45 AM   #10
BlueOval Ralph
Banned
There was also a 12 Bolt made for the G-body. Oldsmobile had it done and was given out to the factory cars. Just like the non computer q-jet & Dist. There were parts from Canada.
Ralph
QUOTE=skooter;132274]They make the control arms to put the "A" body rear in the "G" body, with the correct angles.
Can't remember who, maybe the "Iceman", I think there's a product line under that name, think he even sold/sells on Ebay.[/QUOTE]
BlueOval Ralph is offline   Reply With Quote
