Old 08-03-2009, 05:39 PM   #11
GRIGGS
Talking Re: Battery
Originally Posted by ERNIE GRIGGS View Post
I remenber that flywheel !!!!!!!!!!!!!!!!!!!!!!! Lol lol
Nice!!!!!
GRIGGS is offline   Reply With Quote
Old 08-04-2009, 03:04 PM   #12
Bill Baer
Default Re: Battery
If you have room for two batteries, then the CSR 24-volt system is tops. Nothing beats spinning over a big inch engine than 24 volts."
I agree with John, I think the 24 volt stuff is a better technology. But being a bit of a cheapskate, I use a red top optima and I buy a new one each year, I also use a powermasters best (Biggest) starter and an east coast electric 70 amp alternator. My set up is a fuel injected 14:1, 540 and it cranks over fairly easy but it can be hard to start and we do crank it about twice as much as of carbureted competitors need to. I also have heard some negative comments about the Optima batteries but to date I haven't had any problems. Hope this helps
Old 08-04-2009, 05:42 PM   #13
199k
Default Re: Battery
That 24 volt does sound like a good idea. The only problem with my car, being a 240" wheelbase, I dont have enough room for two in the nose. I would have to make a plate behind the front wheels for the second one, I might look into that this winter if i still have a problem.
What do you all think about the braile batteries. They are the only company that makes them small enough besides the Rocks, and the specs on there big daddy 12 volt looks more jucier than the Rock that I have now... Have anyone of you tried bothe the Rock or the Braile??
Thanks, Kyle
199k is offline   Reply With Quote
Old 08-05-2009, 02:48 PM   #14
Bill Baer
Default Re: Battery
Some of my friends /competitors run two batteries in front of their feet so if you install a 1/4 aluminum plate up there you could probably bolt them down I think bolting one in front and one in back sounds problematic and I have never seen someone mount two behind the rear axel but with 80-100 pounds of weight back there I'll bet it does cool wheelies
I have no experience with Rock or Braile batteries but I have seen a 12V fan smoke when we hooked up the 16 volt battery charger to my friends car and I notced that when the 16 volt sttuff goes dead it seems to do it all at once.
So if your driving the car back I think an alternator is a good way to keep everything happy including your MSD box.
Good luck
Old 08-06-2009, 07:15 AM   #15
GaryGoFast
Talking Re: Battery
Originally Posted by GRIGGS View Post
Nice!!!!!
We always remember the bad times,
Gary Federico
S/St, S/G 1814
GaryGoFast is offline   Reply With Quote
Old 08-06-2009, 08:30 AM   #16
199k
Default Re: Battery
Swapped to the Braille B3121... What a world of difference. Cranks over so much better! Nothing against Rock, but the Braille is 10 pounds lighter aswell.
Kyle
Old 08-06-2009, 12:26 PM   #17
Dave Polichena
Default Re: Battery
Gary, I remember that bad and good time at VMP when your flexplate took a dump and then Marty got the dq, You were a Happy man.
Dave Polichena is offline   Reply With Quote
Old 08-06-2009, 10:05 PM   #18
voltdr
Liked 100 Times in 51 Posts
Default Re: Battery
What ever battery/starter combo you chose, ALWAYS run a separate ground wire from the battery directly to the block, and use star lock washers for a good connection. I have used a red top for over two years with the same flexplate. Remember, grounding, grounding, ground..................
voltdr is offline   Reply With Quote
Old 08-06-2009, 11:10 PM   #19
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Talking Re: Battery
Just curious.If you use an alternator why do you go and buy a new one every year.
I have the same Optima red in my stocker for 3 years.Granted I don't crank 950CI and 20:1 comp. but
my battery is fine.
I also crank the engine at 40 Deg locked dist. with the ignition off and I put the battery on a rotating
basis in my trailer with a marine battery that i've had for 6 years on a Battery Tender.Maybe that might help?
In the mean time send me your "old" Optimas:-)
P.S. I'm on the same Mopar factory starter for 7 years.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 08-07-2009, 06:30 AM   #20
GaryGoFast
Talking Re: Battery
The lord giveth & the lord taketh away.......cant ever count on that situation happening again Dave
Gary Federico
S/St, S/G 1814
