Old 03-25-2009, 06:57 AM   #1
jturner
jturner's Avatar
Default 68 A-body HELP!
hey guys I need help it blowes the tires off i take timing out to get the car to hook its a dog thinking i,m killing the motor to compinsate for a sup. thats not working its a factory type sup. rear sup. is Wolfe racecraft, all adj. double antiroll bar, strange double adj. shock, factory springs all in factory mounting points 68 chevelle 3550 with driver, ub machine front control arms, strange single front shock, moroso trick spring, car 48. percent to the rear,slicks m/h 26x8.5 any HELP.....thanks.
jturner is offline   Reply With Quote
Old 03-25-2009, 11:46 AM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: 68 A-body HELP!
That's a lot of trick parts with some dainty little slicks...
Jeff Lee 7494 D/S '70 AMX
Old 03-27-2009, 05:21 AM   #3
blasttime
blasttime's Avatar
15 by 10 / 5.5 backspace 28/10.5 MT. There is a difference
blasttime is offline   Reply With Quote
Old 03-28-2009, 01:27 AM   #4
Wow, those are the same tires I use on my 14 second, 4 cyl Stocker.
Old 09-06-2009, 09:23 PM   #5
jturner
jturner's Avatar
got the car to hook on hoosier,s best time 5.70 with some testing looking to go in the high 50,s
Old 09-07-2009, 06:59 AM   #6
james schaechter
I was think the same thing, all good until the tires. If you got it work ever, you were doing pretty good. The tuning window must be pretty small.
James Schaechter 3163 STK
Old 09-07-2009, 08:49 AM   #7
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
I take it your running the 8.5 wide class? If so you running it on just the motor? Are you using a trans brake? If the answer is yes to these don't spary it till it get atleast 60' out & try a lower starting line RPM
Old 09-07-2009, 12:16 PM   #8
72Malibu
72Malibu's Avatar
You can do all you want to the back end, but if the front dont work, you wont hook. My pic is on 30x9x15 slicks. You need some good springs and shocks up front. www.santhuffshocks.com and KONI street adjustables will get er done.....for a while
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 09-18-2009, 08:23 PM   #9
jturner
jturner's Avatar
thank's, I run the 8.5 class with trans brake at 3000, going to try 3600 with timing ramping a little slower, I agree the santhuffs WORK is there a big diference between moroso trick springs and the Moog, i,ve read a few thread,s and a lot guy's are using the moog, that 72 is looking good, thank's again Jeff
