Old 09-27-2009, 08:44 AM   #1
Michigan Skip
Default when swapping out rod bolts from stock to ARP
do you guys do anything to the big end afterwards or just swap them and check with stretch gage?
Skip Willis
95 Z28
IHRA ST/666
Michigan Skip is offline   Reply With Quote
Old 09-27-2009, 09:42 AM   #2
Chad Rhodes
Default Re: when swapping out rod bolts from stock to ARP
they need to be checked for roundness.
alot of the LS1 street car guys swap them in the car, it sometimes leads to failures. Most likely from pulling the cap out of round
Chad Rhodes 2113 I/SA
Old 09-27-2009, 10:38 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
Swapping rod bolts with out resizing the rods is a sure way to end up with spun bearings.
You can check them for roundness after you put them in, but what you will find is the caps don't align with the rod. It usually moves the caps around a few .0001's (Thats tenths of a thousand or more) because the new bolts don't hold the same center as the old bolts. In the 40 years I've done engines I've seen spun bearings many times when someone does a freshen up themselves and doesn't size the rods after changing the bolts. In some of their instructions ARP does suggest the rods be sized when changing bolts . Have your machinest cut the cap and rod side about 1 1/2 to 2 thousandths each and then put the bolts in and resize. That will give enough to work with and it will only shorten the rod 1 to 2 thousandths. It is my opinion that you might roll the dice and get by without resizing, but that is one of those pay now or pay later things.....
http://www.arp-bolts.com/catalog/Catalog.html
Look at step 4 of the ARP instructions from page 33 of their web site about How To Install OEM-Style Bolts.
Adger Smith (Former SS)
Old 09-27-2009, 06:40 PM   #4
kansas stocker
Liked 250 Times in 49 Posts
Adger is 100% correct. We did a little experiment with rod bolts and I think it worked on 1 out of 10 rods. Not the kind of odds I would want to bet against..
kansas stocker is offline   Reply With Quote
Old 09-28-2009, 03:41 PM   #5
Ed Wright
Ed Wright's Avatar
I can't believe how many LS1 internet kids tell me they swap them out in the car. They tell me "Everybody on (fill-in-the-blank).com does it." Friggin insane.
Ed Wright 4156 SS/JA
Old 09-28-2009, 05:47 PM   #6
art leong
Do they have a "cracked cap rod" the stock rod neon guys do it to. I'm told you can't resize "cracked cap rods"
One reason I used aluminum rods.
Art Leong 2095 SS
Old 09-28-2009, 06:59 PM   #7
Clevite makes a special bearing for the "cracked rod" in the LS-1, and the regular small block. It is 0.001" bigger on the OD. Made especially for rods that cannot be cut on the cap or the rod.
