Old 10-03-2009, 07:23 PM   #1
Robbie Welch
Liked 262 Times in 124 Posts
Default Throttle stops brands
Looking to up date my old spring closed air open leakage style. Thinking about an under the carb air on air off unit. I have a couple questions,with a 2"spacer on to check clearance the hood clearance to the bowl vents look close, how much clearance do you need for them? What brand of under carb or leakage style stops is everyone using. Thanks for the help Robbie
Old 10-03-2009, 08:12 PM   #2
Keith 944
Keith 944's Avatar
Default Re: Throttle stops brands
ha, would not take my word for it, #1 stop, dual , air on and off, wait for every hitter to responed to the same, btw when i footbrake race i just replace with a 2" spacer, with my air filter and scoop pan it has to be the correct size. thanks for the confidence mr. yoder! lol...
Old 10-03-2009, 08:21 PM   #3
Keith 944
Keith 944's Avatar
i took the vents out of the dodge because they almost hit the hood, so i cut about an 1/2-1'" off replaced and used a peice of clear hose and cut a slice out of the center, clears fine and works great...
Old 10-03-2009, 09:39 PM   #4
Lou SG2340
Air 1 Stop only way to go. They make an electric but you can't adj. the closing & opening rate.
Lou SG2340 is offline   Reply With Quote
Old 10-03-2009, 10:52 PM   #5
Robbie Welch
Keith! I can't trust a chicken pluckers word. Unless it's about chickens. hehehe Lou thanks for the advise. Thats two votes for #1 stop any body else want to chime in. Thanks Robbie P.S Keith Good luck in Rockingham
Old 10-04-2009, 12:38 AM   #6
Chris Williams
Chris Williams's Avatar
Love our Dedenbear TS-6.
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 10-04-2009, 01:33 PM   #7
Bryan Gillespie
Banned
Thumbs up Re: Throttle stops brands
Originally Posted by chris williams View Post
love our dedenbear ts-6.
x2
Bryan Gillespie is offline   Reply With Quote
Old 10-04-2009, 09:15 PM   #8
GRIGGS
Make that 3.
GRIGGS is offline   Reply With Quote
Old 10-06-2009, 06:55 AM   #9
tom1280sc
#1 stops only way to go. Currently own 3. Two for 4500, one for 4150.
Does that count as 3 more votes ?
tom1280sc is offline   Reply With Quote
Old 10-06-2009, 07:09 AM   #10
Robbie Welch
Thanks for all the replys. Any body else? It looks like under the carb is the hot lick now? How close can the bowel vents be to the hood. With a 2" spacer mine are about a 1/4 " from the hood.
