Old 01-05-2010, 11:55 PM   #1
burkeman10
Default Trans Trigger
I have seen a lot of posts on other forums about the Trans Trigger but have never seen where you could purchase one. Anyone Know??????
burkeman10 is offline   Reply With Quote
Old 01-06-2010, 06:54 AM   #2
danny waters sr
danny waters sr's Avatar
Thumbs up Re: Trans Trigger
Call Danny Waters Jr @ 252 525 1605
Old 01-06-2010, 08:58 AM   #3
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: Trans Trigger
ok i'll bite. what the heck is a trans trigger ?
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 01-06-2010, 09:09 AM   #4
Bob Verwold
Bob Verwold's Avatar
Thought the same thing...........only thing I came up with was trans brake switch.
Bob Verwold is offline   Reply With Quote
Old 01-06-2010, 08:45 PM   #5
danny waters sr
It is a device in which releases the trans-brake. Rather than a button and mashing it , you actually squeeze a trigger as if pulling a gun trigger. It looks kinda like a quarter stick pistol grip with the lever in front of it (like the part you squeeze to change a gear on the quarte-stick) it is spring loaded . When you want to release the trans-brake all you do is pull the lever while holding the pistol grip in the palm of your hand.Takes away flenching and other variables. Very trick peice. My son has wom numorous rounds with this thing.You also cannot accidently go back on trans-brake once you squeeze trigger, that is what mostly got it approved as for a safety feature on down track trans-brake mis-haps.
Old 01-07-2010, 04:36 PM   #6
PB Candies
Is there a web site and or pictures to look at this devise?
PB Candies is offline   Reply With Quote
Old 01-07-2010, 07:04 PM   #7
danny waters sr
dragraceresults.com bracket talk forum and ask under general discussion.
Old 01-07-2010, 08:38 PM   #8
FED 387
Liked 336 Times in 183 Posts
Exclamation Re: Trans Trigger
Neat idea we have used it before(borrowed one)--- They aint cheap either about $450 !!!!
Not sure if NHRA accepts then either---Neat idea and once you get used to it DEADLY CONSISTENT---Comp 387
Old 01-07-2010, 10:47 PM   #9
danny waters sr
NHRA does accept them. We had it on Danny's dragster at Z-MAX the first race and got down to three cars.
Old 01-08-2010, 08:28 PM   #10
slo stock
The web site is shootthelite.com. It isn't $450.00. They cost about $250.00. Very trick. Will never use a button again.
slo stock is offline   Reply With Quote
