Old 01-25-2010, 11:16 AM   #1
monte509
Default Turbo 400
I am fairly new to racing. I was wondering if there is anyone that runs a turbo 400 in Super Street.
monte509 is offline   Reply With Quote
Old 01-25-2010, 11:20 AM   #2
sst1988
sst1988's Avatar
Default Re: Turbo 400
Yes many racer's use a 400 in SS/T and H/R. but you will need a transbrake.
sst1988 is offline   Reply With Quote
Old 01-25-2010, 12:06 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Thumbs up Re: Turbo 400
I've had great success in the past with the TH 400 in S/ST and even S/G and so have several of my customers. ........with the proper setup they work excellent ......Feel free to PM me for more detailed info. .......Tom
Old 01-26-2010, 09:43 AM   #4
knsrace
I run the 400 with transbrake in my SS/T BB Ford (yes I know it is GM). It’s been very reliable in the 3200 lb Mustang.
knsrace is offline   Reply With Quote
Old 01-26-2010, 01:44 PM   #5
Dave Polichena
I used to do it but have switched over the glide side. A friend of mine uses the 400, shifts to 2nd on time and rpm for 3rd, makes it pretty consistant keeping the rpm down when on the stop and not so crazy when coming back on.
Dave Polichena is offline   Reply With Quote
Old 01-26-2010, 05:30 PM   #6
SCOTT SST2871
I use a th400 and have had problems with the sprag not holding after about40-50 runs.i put a center support from ati with a bearing on it,its supposed to help...but i will say the car is very consistent and dialable with the th400
scott fifield
SCOTT SST2871 is offline   Reply With Quote
Old 02-03-2010, 06:24 PM   #7
Dave Polichena
Scott, I hope that center support helps you, it was almost a common sight to see you pullin the trans out between rounds.
Old 02-04-2010, 09:41 AM   #8
SCOTT SST2871
Hey dave,your absolutely right and it got old..i lost more rounds from that than being beat!! At reynolds i ran desio 2nd round had him pretty good on the tree and it didnt shift into 2nd gear
see you in bradenton scott
