Old 04-11-2010, 09:12 AM   #11
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
Default Re: gas carb?
Originally Posted by carbman1 View Post
Alcohol will almost always pick a car up.2 to.3 methanol burns slower as well as making more torque . You burn 11/2 to 2 times more fuel by compressing and burning a more dense mixture this gives the sensation of having more compression. methanol produces a smoother and more forgiving torque curve and will equal or make more HP than gasoline (That is if the fuel delivery system, carb and ignition are correct)
THANKS
Exactly... Just swapping a Alky carb for a gas one Im supprised it didnt fall off more...We have seen gains of up to .6 going from gas to Alky with ALOT of fine tuning and adjusting...
Just currious if its set up for Alky, why switch back to gas??? Most everyone else is going the other way..
Freddie is offline   Reply With Quote
