Old 04-24-2010, 01:18 PM   #1
6bblflash
Cool Ignition Retard
Is there anyway,other than a programable ignition box/computer to retard timing in just 1 or 2 cyls.?
6bblflash is offline   Reply With Quote
Old 04-24-2010, 01:28 PM   #2
Floyd Gomez
Floyd Gomez's Avatar
Default Re: Ignition Retard
MSD has the selector but you have to move it manually.
Floyd Gomez is offline   Reply With Quote
Old 04-24-2010, 03:00 PM   #3
6bblflash
I looked all over their stuff, all I can find are ways to change the timing in all cyl.s
I need to change just 1 or 2 cyls. ONLY.
What would be the effect of a LONG lpug wire on the cyl. in question?
Juice takes time to get there,would probably have to be pretty long,4-6 ft.?
Old 04-24-2010, 09:45 PM   #4
Floyd Gomez
I dont think you would affect timing enough to notice as spark travels in miliseconds. I know Ishmael performance had an 8 pack coil set up back in the day that you could do what your asking to do. A very easy setup that could be recreated with a bunch of coils. Worked on a points ignition too.
Old 04-24-2010, 10:04 PM   #5
sg1586
Tell me why you need to retard only a couple of cyd????
sg1586 is offline   Reply With Quote
Old 04-25-2010, 08:07 AM   #6
6bblflash
Poor flow in #4 runner,causing detonation.
probably just going to change compression in that cyl.,but was looking for alterantive.
Old 04-25-2010, 05:52 PM   #7
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Before there were programmable boxes, the NASCAR engine builders would bend the tangs on the distributor reluctor for the cylinders they wanted to retard or advance, then check the results by putting a timimg light on each cylinder. I guess it was trial and error until they got the right amount of change.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 04-25-2010, 06:11 PM   #8
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Why not just put a hotter or colder plug in that cylinder.
astikhossw is offline   Reply With Quote
Old 04-26-2010, 06:19 AM   #9
sg1586
Poor flow??? What cyd's and whats the firing order Ford,Chevy??Are you using a carb?? If it's lean in those cyds would more fuel help?? This can be done..
Old 04-26-2010, 04:58 PM   #10
6bblflash
440 Mopar,Edelbrock 6bbl intake. Of course Holley 2300 carbs.
1-8-4-3-6-5-7-2
Only #4 breaks the plug.
