Old 07-01-2010, 05:35 PM   #11
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Default Re: A Arm bushings
all my urethane bushings have bitten the dust over the last year on my 1970 big block Velle. All left are a real sloppy mishandling collection in the front end. Time for a new set and I'm on the fence as to which way to go, del a lum or afco solids. any opinions on whys or why nots on them?
chris ok is offline   Reply With Quote
Old 07-01-2010, 06:58 PM   #12
72Malibu
72Malibu's Avatar
For drag racing applications, I will always suggest racers to not use poly graphite or urethane bushings since with time, they will deform and deteriorate. If was to to suggest a bushing, I would rather use, due to its properties, Nylon.
How long does it take them to deteriorate? I've had mine in for a little over 2 years, front end is still tight.
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 07-01-2010, 08:53 PM   #13
SSDiv6
My preference is Global West Del-A-Lum over any other brand. Another source for good bushings and other accessories is UB Machine. AFCO bushings have higher friction.
UB Machine is the biggest manufacturer of chassis components for other companies such as Alston, Port City Racing, S&W and others. http://www.ubmachine.com/index.html
Old 07-01-2010, 08:56 PM   #14
SSDiv6
There are many variables that influence the life of the urethane bushings; they either deteriorate or bind when they go bad.
Old 07-01-2010, 09:35 PM   #15
chris ok
chris ok's Avatar
72 Malibu, you might have plenty of time with them. Mine lasted many years and were street driven. I noticed how bad mine were changing front springs. First ones bad were drivers uppers. redid them like 4 years ago. lowers were 2 years ago. pass side is all fried this year. works out to I got 10 years on'em. I had a spare set I used to replace drives side but time for a complete re bush.
Old 07-21-2010, 10:31 AM   #16
phantom1010
I use the Afco solid uppers with zerk fittings.SST 7009
phantom1010 is offline   Reply With Quote
