Old 07-05-2010, 09:54 AM   #1
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
Default Battery mounting
Which is the best way to mount a battery? Lengthwise or crosswise? Does it make a difference in battery life?
Floyd Staggs 787 SST
Old 07-05-2010, 11:16 AM   #2
SCOTT SST2871
Default Re: Battery mounting
Floyd i always mount them crossways(with the terminals on the left and right side) because the acid crashing against the plates on launch will eventually short the battery!!if its a dry cell or gel battery im not sure i use ac-delco standard batterys
scott fifield
SCOTT SST2871 is offline   Reply With Quote
Old 07-05-2010, 11:24 AM   #3
Floyd Staggs
Scott, I use an Optima. Does that make a difference?
Old 07-05-2010, 11:34 AM   #4
Chris Williams
Chris Williams's Avatar
According to Optima, you can mount those suckers pretty much any which way you want.
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 07-05-2010, 11:43 AM   #5
Floyd Staggs
Thanks, I didn't want to drill any more holes in my bed.
