Liked 225 Times in 88 Posts
Has my 67 camaro brake porportioning valve gone bad ? All of the 4 drum brakes work and hold strong and release fine .The main problem is with line lock it just can't lock down front brakes . Put new hurst line lock in end of last year , just due to the old hurst line loc soleniod started to stick/died . It just seams like it holds at half the pressure , compaired to if you just push on the pedal and try to turn the wheels . The line lock is get full 12vdc . All line connected wright in and out . Its the only thing left . Anybody run in to this ? Ken R.
#2 | |
Liked 503 Times in 131 Posts
Eric
Eric Merryfield 1883 STK |
Ya thats what I've been doing just to get by . But it can push you wright out of the burn out and miss putting enought heat in the slicks . I dont think my cars got a porportion valve , I think its just a pressure switch that lights the dash light .
Liked 4 Times in 1 Post
Your last comment is correct- drums on all four won't need a proportioning valve. Try adjusting the shoes to the point they start to drag.
Tony Curcio 1860 STK |
Liked 335 Times in 182 Posts
-try adjusting shoes til they start to drag ---then when you get into the water box pump the brake pedal a few times til it starts to get hard---you'll feel it in your foot--- then with the pedal still on the brake pedal set the line loc ---then start your burn out see if this helps--worked on my 67 camaro with drum brakes--Comp
Liked 7,896 Times in 1,754 Posts
Ken, have you put new lining on it lately? Did you have the new lining re-arched to the drums?
Billy Nees might be onto something. We had the same problem that drove us crazy. We put on new brake pads and new rotors. Turned out that we didn't have the above broken in properly.
Nelson Kowal Stock 345 |
