Old 07-14-2010, 07:45 AM   #1
Stkracer23
Liked 2 Times in 2 Posts
Default Nova wheel backspace
Hi Guys Im new to this site. My name is Josh and Im building a 1969 nova stocker. I was wondering if any of you guys could tell me what back space works on these cars. Id like to run a 10 inch wheel on the rear. I guess 3.5 on the front not sure on the backspace. This is my first racecar any help would be greatly appreciated! Thanks
Stkracer23 is offline   Reply With Quote
Old 07-14-2010, 08:03 AM   #2
Robert Simpson
Liked 20 Times in 12 Posts
Default Re: Nova wheel backspace
On my street 70 Nova with a stock Nova 12bolt, I run a 8" rim with 5.5" backspacing with a 275/60 tire. I have no clearance issues and my car sits lower than stock. I am not sure about the 10" rims I know there are people on here that could answer about this. Hope this helps.
Robert Simpson is offline   Reply With Quote
Old 07-14-2010, 09:16 AM   #3
Stkracer23
Thanks Robert. Im going to run a 30/9 slick. Just trying to find the right combination. So I can order my wheels.
Old 07-14-2010, 10:28 AM   #4
Bobby Zlatkin
Bobby Zlatkin's Avatar
I use a 8" wheel and a 9" x 29" tire on my '73 stocker, Tried a 4 1/2" back space and tire rubbed the outter wheel lip. With a 5 1/2" bs the tire rubbed the inner wheel well. So, I run the 5 1/2" bs with a 1/2" spacer. Not the the best deal, but good luck finding an affordable, good looking 8" wheel with a 5" bs which would be ideal. ot in the Summit or Jegs catalogue.
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 07-14-2010, 10:45 AM   #5
Jim Cimarolli
Liked 166 Times in 46 Posts
Wink Re: Nova wheel backspace
I use a Hoosier radial with a 10 inch rim that has 6 inches of backspacing.
My rear end overall width from axle flange to axle flange is 60.5 inches, everything will just make it with that combo. Of course you have to trim the inner lip of the fender and lightly fold the front trailing edge of the lower part of the wheel opening.
Jim Cimarolli is offline   Reply With Quote
Old 07-14-2010, 03:57 PM   #6
Stkracer23
Thanks alot guys I appreciate all the information! Now I have to decide between the 8 or 10 inch wheel.
Old 07-15-2010, 09:08 AM   #7
Grant Eldridge
Grant Eldridge's Avatar
On my 1970 Nova, a 5.5" bs 10" rim worked, but as above you'll need to roll the lip of the wheel opening, and also hammer in the closest points on the inner wheelhouse. Unfortunately, I can't tell you the exact width of the rear end from memory, when we built the car we started with a wider 12 bolt and narrowed it to the Nova, changed the perches etc. I do know that it is tight, just makes it with the 9" x 30" radial section widths after all the massaging of the inner with a sledge hammer. Of course, an 8" rim with a 4.5"bs is a bit easier as it reduces the section width, but we felt the 10" was the way to go. Be ideal if you could borrow a set for fitting it up before you buy a set....
Grant Eldridge is offline   Reply With Quote
Old 07-15-2010, 09:40 AM   #8
Danny Ashley
Liked 110 Times in 29 Posts
Hi Josh - My friend Mike McDonald runs a 69 Nova 350-255 . If this is the engine you plan to run he has one for sale at a good price and he can also tell you about wheel spacing. I had his car here over the winter and he has no issues with clearence. Buying a proven engine from someone who runs the same car as you will speed your learning curve tremendously. He can help you get in the ballpark in all aspects of your car. His cell is 812-677-1097.
Danny Ashley is offline   Reply With Quote
Old 07-15-2010, 01:02 PM   #9
Stkracer23
I thank you for all the information! This really helps alot. Im not sure if Im going with a big or small block yet. But I agree Danny a proven tested combo would definately help get me started. Im leaning toward a big block stick car. But ill have to see what's available. Id like to find a good used big block engine and jerico trans. Thanks again guys!
