Old 07-14-2010, 12:40 PM   #1
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
Default Bellhousing access window?
I am looking at purchasing a Quicktime Bellhousing, should I order the optional access window? I have heard that the window may not line up with the clutch adjustment. Is this true?
Here is the discription from their website.
RM-6.1 WINDOW
  • Access window for clutch adjustment 1 1/2" x 3 1/2" Hole
  • Can be added to any of our bellhousing
  • Modification must be done by QuickTime
  • Carries a 2 year 6.1w Certification
  • Modification takes approximately 1 week
Thank you,
Larry
Larry Curtis is offline   Reply With Quote
Old 07-14-2010, 01:40 PM   #2
Notch1320
Default Re: Bellhousing access window?
I am sure it would depend on the clutch, and Quicktime could probably assist with answering that question. The window would also make adding or removing CW easier as well.
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 07-14-2010, 02:19 PM   #3
Jeff Lee
Jeff Lee's Avatar
You definitely want this. It allows you to change the counter weights without trying to go through the clutch fork hole or slot. Doing it the old way is like working on a watch with a pair of big wrenches with the fork, shift rods and headers in the way as you try to R&R three small nuts and bolts.
Jeff Lee 7494 D/S '70 AMX
Old 07-14-2010, 02:39 PM   #4
Greg Barsamian
Liked 427 Times in 97 Posts
I've sold a few friends on those bellhousings.
Fact:
*12lbs lighter than a Lakewood
*Not as "square" and "bulkier" as a Lakewood & allows for easier installation & removal with headers!
*Compatable with todays aftermarket transmissions, no cutting, grinding, drilling & tapping.
*Dead-On-Dowel holes, centered without dowel modification when installed on all the Chevrolet applications!
*The window offers you exposure to fine tuning with the counterweights.
The Negatives:
* You still have to drill a hole at the bottom of the bellhousing to check your "air gap" once installed!
* You'll need to have the bellhousing re-certified sooner with the "window option"
* You'll need to purchase Lakewoods adjustable pivot ball for correct clutch-fork alignment. The one that comes with the QT bellhousing is not adjustable!
Before you buy Contact Tim Ryherd at The Car-Shop in Illinois.
Jim Schaecher introduced Tim here on Classracer as a"Quick-Times dealer
He's sold a ton of them at great prices.
He'll price quote any version needed.
Tim can be reached at:
The Car Shop Inc.
421 12th street
Moline, IL 61265
http://www.carshopinc.com
sales@carshopinc.com
1-309-797-4188
Hours 9am-5pm M-F Sat 8am-12pm
Old 07-14-2010, 09:38 PM   #5
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Get it with the window you won't regret it. ed
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 07-14-2010, 10:09 PM   #6
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Look here too !
http://www.browellbellhousing.com/index.html
2894 STK
Old 07-14-2010, 11:45 PM   #7
Jeff Lee
Jeff Lee's Avatar
Originally Posted by Kenny Wigington View Post
Of course an extra $1000 to $1500 or so will always buy you the nicer stuff...
Old 07-15-2010, 08:03 AM   #8
Larry Curtis
Will tech give me problems if I drill an extra hole in the bell?
Larry
Old 07-15-2010, 08:24 AM   #9
Greg Barsamian
Larry
Larry, Call Tim at the Car shop.
Old 07-15-2010, 09:40 AM   #10
Ed Carpenter
Cool Re: Bellhousing access window?
Larry
I have raced my car for 3 years now and they have looked under my car exactly "0" times so far. ED
Ed Carpenter
