Old 08-13-2010, 09:06 PM   #1
mrfab
Default Super Comp Dragster Weight?
Can anyone give me a ballpark estimate as to what a SC dragster weighs? I'm helping convert a SC car to run at Bonneville as a gas lakester. I have no access to any scales. The car is a 2002 235 inch Yancer sprung rear car (pivot points behind the driver, 2 shocks) Iron block BBC, alum heads and a PG. Dual optima, fuel cell, and a weight box up front.
mrfab is offline   Reply With Quote
Old 08-14-2010, 10:48 AM   #2
Bill Baer
Default Re: Super Comp Dragster Weight?
My similar hard tail car weighs 1870 with a 260# driver after a pass.
The thing about bonneville is the salt is slippery and they don't want any aero drag so they add ballast to improve down force to keep from spinning the tires @ 200+ So you might want to consider ways to add weight. I'm not sure, but I think they allow water as ballast.
Good luck,the one time I was at Bonneville it had a nice laid back atmosphere.
Old 08-16-2010, 10:11 AM   #3
Chris Williams
Chris Williams's Avatar
Our 97 Yancer 225" hardtail weighs 1805 with a small driver in it. So I'd think you're right about at it with a guesstimate of ~1900 lbs.
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 08-16-2010, 09:34 PM   #4
mrfab
Thanks for the information guys. I'm having a tough time coming to terms that I will have to add HUNDREDS of pounds of ballast to the rear and probably the front too. I can accomplish the same results with wings but that adds alot of drag. It's just going to be alot different from all of my past experience
Old 08-25-2010, 10:37 AM   #5
sc7667
I asked my brother, who works at Yancer, and he said it probably weighs about 1700lbs w/o driver. if it is a big nose car you can probably put between 100-150 lbs in the weight box up front. If it a small nose around 75-100 lbs.
sc7667 is offline   Reply With Quote
Old 11-08-2010, 07:51 PM   #6
7110
I have small nose Yancer with the single shock design, and when I used to run an iron-headed BBC, it weighed about 1720 lb with the front weight box NOT installed.
7110 is offline   Reply With Quote
